Thread: loose intercooler pipe! please help!
  1. loose intercooler pipe! please help!
    Sep 2007
    Hi, i have posted on here regarding a loose pipe, my knowledge has grown a little on the matter and now i know it is a loose intercooler pipe under the near side headlight. I was wondering whether anyone could give suggestions as to how i could solve the problem of making it stay on, which will ultimately restore performance on my 150 tdi and also prevent the smoking from the back! I have heard the terms maf, and egr being mentioned on here but know not what they are.
    Any help will be appreciated
    thanks
    Mash
  2. Re: loose intercooler pipe! please help!
    133 Post(s)
    1992 Post(s)
    The pipes on these blow off due to the steel metal clip wearing away the barb on the aluminium to rubber coupling and the pipe will have to be replaced to stop it blowing off. You can open the barbs up slightly when they have worn through to a hole but it doesn’t last. It is a common problem on the 130 and 150 Golf 4 and plastic coated clips would help but it isn't a very reliable design. Every time the turbo boosts, you can see these fittings move and that is what causes the wear.Whatever happened to worm drive clips?
  3. Re: loose intercooler pipe! please help!
    Sep 2007
    thx for your advice! would you suggest i try using clips other than the ordinary C clip which holds the pipe together!
  4. Re: loose intercooler pipe! please help!
    133 Post(s)
    1992 Post(s)
    I would suggest using a coated clip if such a thing were available.
  1. Loose Door Handle
    By Piez in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-09-2016, 05:12 PM
  2. New intercooler pipe..now not same power
    By gazuk_1 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-08-2007, 08:16 AM
  3. plastic pipe to intercooler.
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-07-2007, 09:42 PM
  4. Loose wire
    By Cara2007 in forum Archive posts
    Last Post: 27-04-2007, 11:23 PM
  5. Loose Gearbox
    By mUNKI in forum Golf MK2 - 1984 - 1992
    Last Post: 13-10-2006, 10:50 PM
