Thread: 2002 AZM 2.0 litre Petrol - Juddering
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. 2002 AZM 2.0 litre Petrol - Juddering
    May 2013
    South
    Well I had this problem about 1-2 months ago, where I'm in 5th gear doing about 30mph, put my foot down and the car judders (to about 1.7k rpm, then it accelerates smoothly) rather than slowly accelerating (like it always has done)
    I got bored and had a look around the engine and there seemed to be a vacuum hose near the back of the engine that didn't seem fully inserted, so I made it snug again, but it was more like if I put it snug one end, then its nearly hanging off the other side, as if it's somehow got slightly too short. When I did this the problem went away (voodoo?) I've since done around 800miles without a problem event went to newquay (250m) each way and not a problem.
    Yesterday when leaving work, when I started the engine it felt odd, best way to describe it, coming home I had no problems though.
    This morning, I got up the road went to accelerate from 1st and it dipped power then picked up and zoomed off (must of looked an idiot) then nearly every gear if I accelerate from below (1.5k rpm) the car judders for abit then it's okay, until I get into 5th and my revs are below 1.7k then I try to acclerate and it's juddery again.
    I don't have access to a scanner, but I think it's sensor/vacuum related (hopefully) any ideas?
    If the hose has come loose again, any idea what would cause it to become loose? I'll be looking furthur after work today
  2. Re: 2002 AZM 2.0 litre Petrol - Juddering
    May 2013
    South
    The day after I posted this, my car was fine. This morning though it was bad and felt abit worse.
    It seems to do it more when the accelerator is fully down, but if it's just down abit it doesn't seem to do it.
    Any ideas
  3. Re: 2002 AZM 2.0 litre Petrol - Juddering
    135 Post(s)
    2026 Post(s)
    This tends to happen if the crankcase ventilation hose is breaking up under the woven cover. which conceals the break but allows un-metered air to be drawn in. Really you do need to get it fault code read. A picture would help with the vacuum hose question.
  4. Re: 2002 AZM 2.0 litre Petrol - Juddering
    May 2013
    South
    Hiya,
    Thanks for your reply. I've ordered a scanner and will use VCDS-Lite when it comes through (next couple of days)
    Where abouts is that part in the AZM engine roughly? Is that the tube at the top back of the engine, that connects to the MAF? If so I should be able to take that off this evening and check the bad boi out
    What I see find odd is that not once has the CEL come on
  5. Re: 2002 AZM 2.0 litre Petrol - Juddering
    May 2013
    South
    Coming home was fun, it was lumpy as hell, I even had the CEL light flash, then stay solid for around 5 seconds, then it completely went :/ No buzzing or dings to say it was on though.
    I remove the tube part and no luck, no holes or anything and seems pretty new.
    There is a tube that if I remove it, the car feels lumpy (http://gru-uk.com/car/IMG_1536.JPG the T tubing), like it does when driving, however when I remove that the car is lumpy in idle, yet my car isn't.
    I put the parts back together and annoying the car was fine, I wasn't happy with it being 'fixed' so I remove the cable to the MAF, took it for a ride but my car seemed quite nippy, but also felt like my suspension went all jelly fied :/ I pulled over, plugged the MAF back in, STILL couldn't replicate the error, but my car did seem less erratic and i'm sure slightly slower, not 100% sure though.
    But after that mini adventure, I pulled up to my house with my engine feeling like new.
    Anything else coming to mind, thats free to check whilst I'm waiting for my scanner?
    Oh, also, I noticed one pipe looking like this http://gru-uk.com/car/IMG_1537.JPG underneath it feels like hard plastic with no marks, just thought I'd mention it
  6. Re: 2002 AZM 2.0 litre Petrol - Juddering
    135 Post(s)
    2026 Post(s)
    Now when you scan it you will have an Air Mass meter fault.
  7. Re: 2002 AZM 2.0 litre Petrol - Juddering
    May 2013
    South
    Hello,
    Sorry for the long delay, my car was fine until yesterday, but I had been waiting for a battery replacement for my laptop to scan away.
    I've got MASSIVE problems with VCDS-Lite, "no controller communcation" then no synch bla bla, I somehow got it working for a second, copied down the codes, reset & went for a drive, but cannot read the errors as VCDS-Lite doesn't work again (maybe my cheap blue cable on ebay?)
    Anyway, it picked up the following codes
    16685 - P0301 - 16685/P0301/000769 - Ross-Tech Wiki - Cylinder 1 Misfire
    16486 - P0102 - 16486/P0102/000258 - Ross-Tech Wiki - Mass Airflow Sensor; Signal Too Low
    16497 - P0113 - 16497/P0113/000275 - Ross-Tech Wiki - Intake Air Temp Sensor (G42) Signal Too High
    Could the MAF cause the other two issues (I'm hoping so, don't like the sound of a misfire )
  8. Re: 2002 AZM 2.0 litre Petrol - Juddering
    135 Post(s)
    2026 Post(s)
    I suspect one or maybe two of those codes will be because you disconnected the AMM and ran it. Clear the codes and drive it again for a few days and re-read then post the results. DO NOT unplug anything with the ignition on.
  9. Re: 2002 AZM 2.0 litre Petrol - Juddering
    Oct 2005
    Quote Originally Posted by danoid View Post
    What OS are you using?
    The words "cheap blue cable" come up a lot when discussing VCDS errors so I suspect it could be the cable but lets start with the OS of the laptop first
  10. Re: 2002 AZM 2.0 litre Petrol - Juddering
    May 2013
    South
    Hello,
    I cleaned the MAF yesterday because I was bored, and the mesh in front was very black and bits inside, so cleaned it out with some contact cleaner and it's been spot on for about 50 miles now (but done this before)
    I've now bought another scanner off ebay, it's one that plugs in and can only read faults, still £10 though but saw that thousands have been sold, so hoping for more reliability
    I tried VCDS-Lite on Windows XP SP3 machine, then Windows 7, still not any joy. I'm not too bothered about VCDS-Lite working, as I found out I couldn't even set the auto lock without registering, and don't think that 1 function is worth £60 to me.
    When I get the scanner, I'll clear, go for a drive (any particular distance) then re-scan.
    Also, dont laugh but where is Cylinder 1 on the AZM? Is it the front of the engine or the back? Tried looking at HT leads but isn't numbered, and the coil pack is basically hidden on the AZM
    btw, I had my sparks, HT leads & coil pack replaced by halfords about 3 years ago, but I don't really do high mileage but is it possible it's one or all three of those causing the misfire?
  1. 2 litre petrol engine oil consumption
    By nilocp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2013, 11:37 AM
  2. Juddering acceleration and loss of power 2002 1.8T petrol
    By paddymm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-07-2008, 03:10 PM
  3. 2 litre petrol engine revs
    By manwithtool in forum Touran - Sharan - Caravelle
    Last Post: 01-11-2007, 12:23 AM
  4. caravelle 2.0 litre petrol
    By Russellbar01 in forum Chat - Completely Off Topic
    Last Post: 17-01-2007, 12:10 PM
