Thread: ClusterII Swap and resetting immobiliser help needed.
Results 1 to 10 of 14
  1. ClusterII Swap and resetting immobiliser help needed.
    Sep 2007
    Fife, Scotland
    Hi All,
    I have an A4Q 1998 pre-facelift which has a dodgey LCD display and I was thinking about doing a swap.
    I have read with interest : http://www.audizine.com/forum/showth...58#post6050358
    I have cluster II, and I found the exact same cluster ( same part no.) and bought it to swap out. I have both original and donor cluster pin codes.
    The original cluster has a 3 digit pin, The donor has a 4 digit pin. The value in Vag-com requires a 5 digit pin. Preceeding 0's to make up 5 digits are accepted as correct.
    I have visited alot of forums to research the swap, and have followed many an article to swap out the cluster.
    I followed the instructions from the Ross-tech website,
    I have read and recorded the data from the original cluster, and loaded it to the donor cluster.
    I have matched the donor cluster to the ecu.
    I have also been able to correct the mileage of the donor cluster to match the original cluster.
    I have tested and am able to restore the donor cluster to its stock state.
    My issue is with the immobilzer.
    I thought by loading the data from original cluster to donor cluster, this should recognise the key.
    In the ODB software there is an option to learn keys, but I have not seen this being used for a cluster swap, but used for blank keys.
    Have I missed a step in the procedure, does anyone know were I have gone wrong, or what I have missed.
    Any help here would be greatly appreciated.
    A4 B5 1.9 TDi Quattro
    Golf Mk3 1.9TD
  2. Re: ClusterII Swap and resetting immobiliser help needed.
    Aug 2012
    Aberdeenshire
    If you have put in a different cluster, you will have to use the SKC to reprogram the keys to the cluster.
    This data is not transferred onto the new cluster.
    VCDS will do this if you have the SKC.
  3. Re: ClusterII Swap and resetting immobiliser help needed.
    Aug 2011
    Meath
    So could I simply put in a different cluster and code the key to it?
    Quote Originally Posted by PaulF2.5TDi View Post
  4. Re: ClusterII Swap and resetting immobiliser help needed.
    Sep 2007
    Fife, Scotland
    I have access to vag-com 409.1, vcds-lite and vagk only.
    So can I use either of these to reprogram the key to the new cluster.
    And if so how do I do it. I know the pin codes of both, is this the SKC?
    I cant seem to find any info on it.
    Golf Mk3 1.9TD
  5. Re: ClusterII Swap and resetting immobiliser help needed.
    Aug 2012
    Aberdeenshire
    Doctle, essentially yes - plug in the replacement cluster, find the SKC of the new cluster and code your keys using the SKC.
    This is what I did on my 1999 MY Avant.
    However, I believe it is not so easy with the higher level immobilisers as the pump has an input too.
    Bigzed, vag-com409 is a cracked copy that has limited functionality. I doubt VCDS Lite will allow you to code the keys and I don't know anything about the other one.
  6. Re: ClusterII Swap and resetting immobiliser help needed.
    Aug 2011
    Meath
    Thanks Paul I'm bad on anything you can't hit with a hammer to loosen them. I am changing the cluster on an 02 Ibiza the car starts and drives fine, no lights come on not even illumination lights it's getting on my wick because it stopped working when I was resealing the sump. I assume they are immo 2 and old style?
  7. Re: ClusterII Swap and resetting immobiliser help needed.
    Sep 2007
    Fife, Scotland
    Hi Paul,
    Thanks for your comments
    The Vag-com and vcds-lite says it is registered, it allows me to log in to channel 17 (instruments) on both original and donor clusters.
    Using option 10 ( adaptation), I can read channel 21, the stored value is "0" and if a new value is entered and tested it returns an error.
    If I login first with pin ( option 11), I can read channel 21 (key adaptation), the stored value on the donor cluster is "0". If I enter a new value (2) and test it holds the new value showing 2, when I hit save the stored value and the new value revert back to "0".
    So I am
    a) assuming I have access to the cluster and permission to adapt key by the pin being accepted. ( btw, I note that vag-com and vcds-lite unregistered copies, throw up an error message to say you cant access these funtions in the controllers, unless its registered.
    Is this scenario the limitation you are refering to in vagcom &vcds-lite.)
    b) a little stumped as why its not storing, the new key adaptation value to the cluster.
    Golf Mk3 1.9TD
  8. Re: ClusterII Swap and resetting immobiliser help needed.
    london/ UK
    log in with pin from new immo then go to ch 21 then when prompted insert each key one by one Then press save,done/go back ! That should adapt each key assuming the clocks are not immo3 !
  9. Re: ClusterII Swap and resetting immobiliser help needed.
    Sep 2007
    Fife, Scotland
    Hi Adam,Can you clarify,
    "log in with pin from new immo" -with the 5 digit pin?
    "then go to ch 21" - check/ok
    then when prompted- there is no prompt after going to ch21 only read is an option, after reading you can enter a new value to test and save. The only prompt I get is when you save and it asked to confirm.
    insert each key one by one- The key is already in the ignition and turned "ON", Should I save before removing the first key, or remove the key after testing, and insert and turn ON the ignition with the second key then remove and then press save. Wont the VCDS-lite disconnect when the ignition is off?. During this the immobiliser light is continually flashing, I read somewhere it was only supposed to flash twice , then go off when the key is recognised.
    That should adapt each key assuming the clocks are not immo3 ! - I dont believe the clocks are immo3, as the ID is only 14 digit and not a VIN style no.
    Thanks for your suggestions.
    Golf Mk3 1.9TD
  10. Re: ClusterII Swap and resetting immobiliser help needed.
    london/ UK
    Google is your friend, go to rosstech wiki and see immo2 key matching procedure...
  1. Please Help Resetting a Scorpion immobiliser
    By Alfonzo in forum Golf MK3 - 1993 - 1999
    Last Post: 10-01-2013, 11:57 PM
  2. HELP NEEDED resetting satnav mmi basic plus
    By dave798 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-05-2011, 05:20 PM
  3. Question ECU swap - immobiliser recode?
    By skipi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2011, 10:28 PM
  4. Please Help Help/ info needed immobiliser A3 1999
    By hammond in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 12-06-2009, 02:59 AM
  5. a4 1.8t blown engine swap needed
    By gticraig in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-02-2008, 07:49 PM
