Thread: 3G HDD software update
  1. 3G HDD software update
    Nov 2008
    Beverley East Yorkshire
    I had my car in to the local dealer today to get an alloy repaired after some careless Parking.
    I borrowed a brand new a4 and I found the mmi interface/ software so much easier to navigate over my 2011/12 version.
    Can just the software be updated or does the unit require upgrading?
    Unauthorised commercial link removed as per forum rules
  2. Re: 3G HDD software update
    46 Post(s)
    The car probably had the 3G+ system fitted over your standard 3G system.
    Big money to upgrade as literally everything needs replacing and numerous component protection removed.
  3. Re: 3G HDD software update
    Nov 2008
    Thanks for the quick reply Chris.
    Not sure what system it was but I assume it will be the plus. Lots of graphics and back lit green icons?
    Shame it cannot simply be re loaded, I can remove component protection.
    When you say everything needs changing are we talking main HDD unit? or screen, mfsw and control panel?
  4. Re: 3G HDD software update
    46 Post(s)
    Yeah if it only had 4 outer buttons on the MMI panel compared to your 8 then it's 3G+
    There was a thread I have saved on my computer showing it being done to a B8 and from memory it was a lot of work, everything MMI related bar the dis and MFSW had to be replaced.
    I'll have a look for the thread now.
  5. Re: 3G HDD software update
    Nov 2008
    Yeah I have the 8 button panel so that would need changing too! Seems it might be cheaper just to change the car ha ha
  1. HDD Sat Nav 2013 Map Update Identification
    By jeznewsome in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-02-2013, 06:29 PM
  2. Software Update
    By grobinson73 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-12-2012, 09:10 PM
  3. MMI 3G HDD Nav Map Update
    By MFGF in forum In Car Entertainment
    Last Post: 22-05-2012, 11:18 PM
