Thread: 2008 A6 crankshaft oil pressure sensor failure.
Results 1 to 10 of 16
  1. 2008 A6 crankshaft oil pressure sensor failure.
    Apr 2013
    gloucester
    Hi everyone, has anyone had this happen- not a cheap job as apparently its a 7-8 hour job. OUCH .
  2. Re: 2008 A6 crankshaft oil pressure sensor failure.
    Nov 2009
    46 Post(s)
    Quote Originally Posted by 1966baz View Post
    Which engine?!
  3. Re: 2008 A6 crankshaft oil pressure sensor failure.
    Apr 2013
    gloucester
    Hi Chris, it's the earlier engine I guess as it was registered March 2008. Occasionaly it would just cut out regardless of road conditions, speed etc. I would put it into neutral and it would start again no probs. Cheers Nick.
  4. Re: 2008 A6 crankshaft oil pressure sensor failure.
    Aug 2011
    Meath
    Do you mean a crankshaft position sensor? What is your engine code?
  5. Re: 2008 A6 crankshaft oil pressure sensor failure.
    Apr 2013
    gloucester
    Hi , the engine code starts BRE ENDING GYX. I will find out more from the garage next week exactly what the part is. Thanks for the replies Chaps.
  6. Re: 2008 A6 crankshaft oil pressure sensor failure.
    Aug 2011
    Meath
    It's a 2.0 TDi, there's no crankshaft oil pressure sensor that I'm aware of. Sensors wear out over time and they're usually easily accessible most can be replaced in 60 minutes or less
  7. Re: 2008 A6 crankshaft oil pressure sensor failure.
    Jul 2013
    76 Post(s)
    Do you mean the oil pump shaft replacement ?
  8. Re: 2008 A6 crankshaft oil pressure sensor failure.
    Jun 2007
    There is no crankshaft oil pressure sensor. The engine is a BRE and it sounds like the oil pump has failed due the the bad design of the oil pump and balance shaft. Regards Peter
  9. Re: 2008 A6 crankshaft oil pressure sensor failure.
    Apr 2013
    gloucester
    Quote Originally Posted by Peter D View Post
    Apparently there are two oil pressure sensors and the garage are going to find out which one has failed on Wednesday- hopefully not too expensive as it should be easily accessible. They initially thought that it was a sensor built into or near the oil pump.If there was a major problem with the oil pump surely the engine management light would come on. Ill keep you posted.
  10. Re: 2008 A6 crankshaft oil pressure sensor failure.
    Aug 2011
    Meath
    it takes less than 6 hours to change the oil pump and that's a big job. Are they still going with 7-8 hours?
  1. Oil Pressure warning - have I the dreaded major failure!
    By new2vwa in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-04-2013, 06:44 PM
  2. STOP oil pressure warning - oil pump failure! Help please
    By jamer78 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2012, 03:54 PM
  3. Please Help help! turbo failure engine damage caused by oil pressure?
    By sillydior in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 15-05-2011, 04:43 PM
  4. Low Oil Pressure Injector Failure message
    By abrucken in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-12-2009, 07:34 PM
  5. Please Help Audi A4 Dash Failure - Oil Pressure Light
    By Caz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-05-2008, 03:23 PM
