Thread: water getting into passenger footwell 2005 A4 cabriolet
  1. water getting into passenger footwell 2005 A4 cabriolet
    Oct 2013
    England
    Hi all
    I still have a problem with water getting into the passenger footwell. I have followed the advice and removed the two drain plugs in the plenum chamber one of which was blocked and washed out thoroughly and the water now drains properly. The the problem still persists albeit not quite as bad as before. The carpet seems to start wet quite high up on the inner sill just under the door towards the front. The door seals seem fine. Really would appreciate your help.
    Regards
    Nigsy01
  2. Re: water getting into passenger footwell 2005 A4 cabriolet
    Sep 2008
    chester
    17 Post(s)
    Check around the pollen filter see if the cover is fitted correctly.
  3. Re: water getting into passenger footwell 2005 A4 cabriolet
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Is your windscreen sealing well
  4. Re: water getting into passenger footwell 2005 A4 cabriolet
    Oct 2013
    England
    Hi all
    I have removed the pollen filter housing completely and found a build up of leaves and other crap at the back forming a dam and holding back the water. There is a foam seal with a black waterproof backing at the base of the housing. Although the foam was wet it seemed to be in relatively good condition so cleaned everything up and replaced everything. I thoughT that i had solved the problem but the next time it rained the water was back. Before i start using silicone is there anywhere else the water could be coming from? Where does the water drain from the cabriolet roof? Any help would be much appreciated :-)
    I have ordered a new pollen filter housing both parts from Audi, should be here Wednesday or Thursday. Logically its the only place that the rain is getting through. Will let you know if it fixes the problem.
    I fitted the new parts but the problem turned out to be a blocked drain from the roof. In a very heavy downpour i noticed water run into the footwell from under the A pillar trim. It turns out that the drain was completely bunged up with crap causing the rainwater to back up and enter footwell. The car in now water tight, anyone with a CABRIOLET might benefit from checking those roof drains out out.
  5. Re: water getting into passenger footwell 2005 A4 cabriolet
    Aug 2014
    Catergam,Surrey,United Kingdom
    Hello i have same isue and plenum drains all clear, where can i find the roof drains plz and any pics?
    thanks
    mike
  6. Re: water getting into passenger footwell 2005 A4 cabriolet
    Oct 2013
    England
    The roof drains start at the top of the windscreen pillars on either side. They look like small holes. If you open the doors you can follow them.down to above the door hinges . They appear to funnel out or get wider towards the bottom. You can gently lift the bottom up and clean any accumulated crud out. This was definetly the cause of my problem and is now cured.
    Hope it helps
    Regards
  7. Re: water getting into passenger footwell 2005 A4 cabriolet
    Aug 2014
    yep all helped thanks, solved the issue which was the entry point of the rear sil by rear wheel, a bung hole blocked
    thanks for advice
  1. Question water in rear passenger footwell
    By toptek in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-10-2012, 06:13 AM
  2. water in passenger footwell
    By mikeosborne13 in forum Golf MK6 - 2009 - 2013
    Last Post: 06-05-2010, 01:00 AM
  3. Water in Passenger Footwell
    By Paulpro in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-03-2009, 11:52 PM
  4. Please Help water getting into passenger footwell
    By saxaphone in forum The Commercial Range
    Last Post: 20-12-2008, 09:22 PM
  5. Water in rear passenger footwell
    By avantiblue in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2007, 01:43 AM
