Thread: water leak/musty smell
  1. water leak/musty smell
    Sep 2007
    hi, new to this, first post. i have a 2001 tdi which had a water leak, now fixed. however there still is a bad smell when there is warm weather, a damp musty smell. cant find any wet or damp spots on the floorwell. had carpet washed but still there, smell seems to be coming from front end, behind or below the dash, could the water have damaged behind the dash?
  2. Re: water leak/musty smell
    Aug 2007
    have you looked under the battery in case the drain hole there is clogged and so assisting water to accumulate. While mine was like that I had a damp smell although nothing appeared to get through into the car. Damned leaves !
  3. Re: water leak/musty smell
    A, A
    Could be blocked pollen filter or fungus in your air con system if it smells when on.
    Just another B7 Estate
  4. Re: water leak/musty smell
    Aug 2006
    cheshire
    carpet may feel dry on top,but,the carpets are about 2" thick!,remove trims on sill to see what lurks underneath.plenty of links n tips on this cursed subject.pollen filter trays,drain holes under battery etc.worth a day,and it will be a day checking all these things out
  5. Re: water leak/musty smell
    Sep 2007
    Think I may have found the problem, plastic strip at bootom of windsreen is not flush with the windscreen, its about 3mm above the screen, could this be it? If so do what do i do to get rid of smell?
  6. Re: water leak/musty smell
    I found a couple of good steam cleans of the carpet as it kills any mould that may be living in it.
    Ade
    __________________________________________________ _____________________
    VW B5.5 SEPD 130
  7. Re: water leak/musty smell
    Quote Originally Posted by easylifeauto View Post
    Easy is definatley right. You need to pull up the carpet and dry out underneath. I'm in the process of doing this.
    http://www.headfuzz.co.uk/?q=vw_ccm
    Naush
  1. musty smell in cabin
    By dubourg in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-03-2010, 10:31 AM
  2. water leak !
    By hitachi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-07-2007, 08:57 PM
  3. water leak
    By johnmccoubrey@t in forum Alhambra
    Last Post: 23-06-2007, 10:45 PM
  4. Water Leak
    By silentwitness in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-06-2007, 11:05 PM
  5. Water leak
    By toledotourer in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-10-2006, 04:13 PM
