Thread: VCDS Help, airbag
Results 1 to 10 of 10
  1. VCDS Help, airbag
    Jul 2013
    Oldham
    hi, since owning the car this fault has been there for the airbags, can anyone help? I cant access the airbag controller and it says something about RON files. I borrowed a lead off a mate until I can afford a genuine ross tech one. is the access problem due to not using a genuine vcds lead? and help on the fault codes, Friday,04,October,2013,21:56:40:55062
    VCDS Version: Release 11.11.4
    Data version: 20120807
    Chassis Type: 8T0
    Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 56 62 72
    VIN: WAUZZZ8KX8A027605 Mileage: 129620km/80542miles
    01-Engine -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
    Part No SW: 03L 906 022 B HW: 03L 906 022 B
    Component: R4 2,0L EDC H01 3210
    Revision: --H01---
    Coding: 0104002C18072118
    Shop #: WSC 99999 102 20971
    ASAM Dataset: EV_ECM20TDI03L906022B A01014
    ROD: EV_ECM20TDI03L906022B.rod
    VCID: 244C5BFA2F0CE93865D
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 AQ HW: 8K0 907 379 AQ
    Component: ESP8 front H03 0210
    Revision: -------- Serial number: --------------
    Coding: 164D00
    Shop #: WSC 06325 123 12345
    VCID: 8814AF4A3BE4AD58E95
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
    Component: BCM2 1.1 H70 0134
    Revision: 00002001
    Coding: 031100
    Shop #: WSC 06325 000 00000
    VCID: 3064A7AA63F44598915
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H37 0060
    Subsystem 2 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
    Component: ELVAUDIB8 H35 0039
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T2 820 043 M HW: 8T2 820 043 M
    Component: KLIMA 3 ZONEN H05 0120
    Revision: D0000000 Serial number: 0118.02.080615
    Coding: 34040000
    VCID: 3C7C839ABFBCB1F83DD
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 HW: 8K0 907 063
    Component: BCM1 1.0 H21 0253
    Revision: 01021001 Serial number: 00000000099704
    Coding: 690040B100148F000001000000005F5F001D02080000014100 0000
    VCID: ECDCF3DA0F5C61786DD
    Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 180208 H05 0060
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
    Component: E1 - LDS H07 0070
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 B HW: 8K0 919 475
    Component: PARKHILFE 4K H06 0010
    Revision: 11001001 Serial number: 75330805611040
    Coding: 000003
    VCID: 38749F8A8B849DD8D95
    Address 15: Airbags () Labels: None
    Component: AirbagVW-AU10 0410
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 00000 000 00000
    VCID: 55AA363E34D640B0223
    No ASAM data for: "" (AU48)
    7 Faults Found
    13697280 - ROD - Unknown Error Code
    - 00 [129]
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 15
    13636352 - ROD - Unknown Error Code
    - 00 [129]
    Freeze Frame:
    Fault Priority: 15
    13636096 - ROD - Unknown Error Code
    - 00 [129]
    Freeze Frame:
    Fault Priority: 15
    10485833 - ROD - Unknown Error Code
    - 49 [129]
    Freeze Frame:
    Fault Priority: 15
    10485769 - ROD - Unknown Error Code
    - 09 [129]
    Freeze Frame:
    Fault Priority: 15
    10485829 - ROD - Unknown Error Code
    - 45 [129]
    Freeze Frame:
    Fault Priority: 15
    10485908 - ROD - Unknown Error Code
    - 94 [129]
    Freeze Frame:
    Fault Priority: 15
    Address 16: Steering wheel (J527) Labels: None
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H10 0012
    Revision: -------- Serial number: 90304HBI0009D
    Coding: 000016
    VCID: 3D7A8E9EA4A6B8F00A3
    Component: E221 - MFL H02 0003
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
    Component: KOMBIINSTR. H14 0216
    Revision: 00100000 Serial number: 7BY17WT28
    Coding: 2F1F080003002600010001
    VCID: 3162A2AE68FE4C909EB
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 D HW: 8T0 907 468 D
    Component: GW-BEM 5CAN H04 0084
    Revision: GA801030 Serial number: 3000G082018233
    Coding: 000003
    Shop #: WSC 00544 210 91416
    VCID: 4280FD62DD58C708771
    Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
    Component: J367-BDM H03 0150
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 C HW: 8K0 959 793 A
    Component: TSG FA H10 0170
    Revision: Serial number: 0000006882751
    Coding: 011202205401410001
    VCID: 4084F76AD354D518615
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0109848499
    Coding: 011F062000390440012001
    Subsystem 1 - Part No: 8K0 951 177
    Component: DWA-Sensor H02 0030
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
    Part No SW: 8T0 035 223 J HW: 8T0 035 223
    Component: DSP STD H07 0210
    Revision: S1700000
    Coding: 0203010101
    VCID: 356A96BE9C9660B0C23
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 C HW: 8K0 959 792 A
    Component: TSG BF H10 0170
    Revision: Serial number: 0000006862672
    Coding: 011202204401410001
    VCID: 3F86F496AEAAAAE018F
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
    Component: EPB Audi B8 H04 0050
    Revision: 00000003 Serial number: 00000000087441
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8T2 035 186 B HW: 8T2 035 186 B
    Component: Concert3 H11 0130
    Revision: 00000510 Serial number: AUZ5Z6H1027235
    Coding: 0002008001010D00435B870000
    VCID: 37769CB6869A92A0D0F
    Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
    Component: Display
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
    Component: TSG HL H06 0170
    Revision: Serial number: 0000006861532
    Coding: 010002204001210001
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
    Part No SW: 8K0 959 794 A HW: 8K0 959 795 A
    Component: TSG HR H06 0170
    Revision: Serial number: 0000006856034
  2. Re: VCDS Help, airbag
    Ambler, PA, USA
    Quote Originally Posted by Sparky_143 View Post
    .... is the access problem due to not using a genuine vcds lead?
    Indeed it probably is. The party that ripped off the product, did not supply all of the ASAM data required and so the cloned product is not able to access the control module. Notice the coding is all zeros. The clone is not interpreting information properly. I suggest you don't mess with high level functions with that clone.
  3. Re: VCDS Help, airbag
    Jul 2013
    Oldham
    This is an email reply from ross tech after using a genuine lead
    There are different types of control modules in vehicles. To that end, on
    modern cars, there can be "CAN" protocol modules, and "UDS" protocol
    modules. The Airbag module is a UDS version. The Engine Control Module is
    also a UDS type module. With these types of modules, VCDS has to identify
    the specific module and then uses a "ROD" file to interpret the data from
    the module into something useful for us to look at. However, the Airbag is
    not reporting a part number. This is what your report shows:
    ---------snip-(your scan)----------------------------
    VCID: 55A5D78534A88DB6975-8000
    We should see something more like this:
    ---------snip-(sample scan)-------------------------- Address 15: Airbags
    (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
    Component: AirbagVW-AU10 H26 0410
    Serial number: 0038JD127MYN
    Coding: 30323433363030303030554A305238543053
    ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 3C7C36AE4031B1FC
    Since your Airbag module is not reporting a part number, I'm thinking the
    module itself might not be to factory design. A few things that come to
    mind that could cause something like this... voltage issues could damage the
    module.
    The first fault code that is listed, 13697280, that DTC number looks to be a
    Component Protection: Active code. Component Protection is something that
    only the dealer can resolve.
    U1101 - Ross-Tech Wiki
    Regards.
    Jef
    Ross Tech Support Team
    Ross-Tech: Home
    On 10/27/2013 8:09 AM, Nathan Kowalski wrote:
    Hi Guys,
    Could you help with these ROD files? Unsure as to what they mean?
    Many Thanks & Yours Sincerely,
    Nathan
    Log: before
    Friday,25,October,2013,14:56:36:43483
    VCDS -- Windows Based VAG/VAS Emulator
    Chassis Type: 8K (8T0)
    VIN: Mileage: 130310km/80970miles
    09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status:
    OK 0000 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status:
    OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status:
    Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv.
    -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000
    Revision: --H01---
    VCID: 2443BA412F72243ED0B-8071
    Readiness: 0 0 0 0 0
    Coding: 164D00
    VCID: 881B4EF13B9A605E5C3-80DD
    Revision: 00002001
    Coding: 031100
    VCID: 306B4611638A889E243-8065
    Coding: 34040000
    VCID: 3C736221BFC27CFE88B-8069
    Coding: 690040F100148F000001000000005F5D001D02080000014100 0000
    VCID: ECD312610F22AC7ED8B-80B9
    1KX-955-119.CLB
    Coding: 00FD11
    8K0-955-559.CLB
    Coding: 025028
    1 Fault Found:
    02095 - Component Protection Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 55
    Reset counter: 48
    Mileage: 130156 km
    Time Indication: 0
    Date: 2013.10.20
    Time: 13:45:00
    Coding: 000003
    VCID: 387B7E318BFA50DE6C3-806D
    7 Faults Found:
    - 00 [129]
    Freeze Frame:
    Fault Priority: 15
    - 00 [129]
    Freeze Frame:
    Fault Priority: 15
    - 00 [129]
    Freeze Frame:
    Fault Priority: 15
    - 00 [129]
    Freeze Frame:
    Fault Priority: 15
    - 00 [129]
    Freeze Frame:
    Fault Priority: 15
    - 00 [129]
    Freeze Frame:
    Fault Priority: 15
    - 00 [129]
    Freeze Frame:
    Fault Priority: 15
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Coding: 000016
    VCID: 3D756F25A4D875F6BF5-8068
    VCID: 316D4315688081962BD-8064
    Coding: 000003
    VCID: 428F1CD9DD260A0EC27-8017
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 25
    Reset counter: 19
    Mileage: 130145 km
    Time Indication: 0
    Date: 2013.10.18
    Time: 18:06:03
    VCID: 408B16D1D32A181ED43-8015
    2 Faults Found:
    02615 - Fuel Tank Cap; Lock
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 59
    Mileage: 130145 km
    Time Indication: 0
    Date: 2013.10.18
    Time: 18:11:02
    02616 - Fuel Tank Cap; Unlock
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 11
    Mileage: 130145 km
    Time Indication: 0
    Date: 2013.10.18
    Time: 18:11:14
    Revision: S1700000
    Coding: 0203010101
    VCID: 356577059CE8ADB6775-8060
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 48
    Mileage: 130156 km
    Time Indication: 0
    Date: 2013.10.19
    Time: 14:22:34
    Freeze Frame:
    Voltage: 12.20 V
    Temperature: 14.0°C
    Bin. Bits: 00000001
    VCID: 3F89152DAED467E6AD9-806A
    Coding: 0002008001010D02435B070000
    VCID: 37797D0D86E45FA6659-8062
    Component: Display
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 48
    Mileage: 130156 km
    Time Indication: 0
    Date: 2013.10.19
    Time: 14:22:35
  4. Re: VCDS Help, airbag
    Jul 2013
    Oldham
    So, what do you all think?
    Is it a knackered module due to voltage? Or is it got component protection active?
    only reason I ask is if you look at the scan there are a few faults which show component protection active but the module can still be read.
    Where is the airbag module located on the b8 ?
    does anyone know what the correct part number should be?
    with there being a few component protections active, will audi charge per module to correct or just an hourly rate?
    will the airbags still work In a crash with the way it is now?
    Sorry for all the questions
    cheers
  5. Re: VCDS Help, airbag
    Jul 2013
    Oldham
    can anyone help on what ,y next step should be? cheers
  6. Re: VCDS Help, airbag
    Nov 2009
    46 Post(s)
    Update to the latest program version.
  7. Re: VCDS Help, airbag
    Jul 2013
    Oldham
    I don't know the version he used, I paid a guy from audisport.net (N8) to do the scan as no one on here could help when I went through the map. I assumed he is all up to date because he emailed ross tech
  8. Re: VCDS Help, airbag
    Jul 2013
    Oldham
    Can someone help with the location of the air bag module on my b8 and what the correct part number is, please. Just want to check it's the rigt module and no cables have come loose before taking it to audi to get the component protection possibility looked at.
  9. Re: VCDS Help, airbag
    Jul 2013
    Oldham
    Just been reading the handbook and it says the airbag light should stay Lit for 2 secs when the car is started
    Mine doesn't light up at all,
    Is this because component protection is active or faulty
    cheers
  10. Re: VCDS Help, airbag
    Jul 2013
    Oldham
    just a little update, spent all night trying to locate the module and finally found it, its located under the armrest area but you have to remove the full centre console to get access to it. anyway had a look at the module and it definitely has signs that it has been tampered with, all the security screws have been damaged. question is, why would someone need to go into the module, what have they done and can it be fixed? cheers
  1. Airbag Fault VCDS scan
    By hitachizx in forum Golf MK4 - 1999 - 2004
    Last Post: 04-01-2013, 08:32 PM
  2. VCDS diagnostics & airbag light reset - suffolk
    By mathoo19 in forum VCDS - Help Requests
    Last Post: 29-11-2012, 05:25 PM
  3. VCDS or OBD tool to reset Airbag light - South Manchester
    By gazza007 in forum VCDS - Help Requests
    Last Post: 31-07-2012, 11:30 AM
  4. Airbag Fault after trying to switch back on Passenger Airbag
    By platty25 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-08-2011, 10:47 AM
  5. VCDS Help needed, airbag warning
    By ascotsteve in forum VCDS - Help Requests
    Last Post: 20-04-2011, 10:39 AM
