Thread: Flashing Glow plug warning light - Limp mode - VCDS Codes - help
  1. Flashing Glow plug warning light - Limp mode - VCDS Codes - help
    Feb 2007
    Hope someone can help, I've looked through the forum and read a lot of posts about this issue, which unfortunately seems to be quite common : (
    I've recently bought a A4 Avant 3.0 TDI Quattro S Line Tip Auto 55 plate BKN. Lovely car, but it's being a little temperamental! I've been getting the Glow plug warning light coming on all the time, which puts it into Limp mode.
    Oddly this problem only started after the right rear brake bulb blew. (I was told by my local garage that this can weirdly cause the glow plug light to come on, and that this particular model has a very sensitive ECU).
    I booked the car into the garage as the brake pad warning light was also constantly on. I had the front discs and pads replaced, had a Diagnostic scan and a reset of all the fault codes, and the car drove like a dream….. until 2 weeks later, bam Glow plug light back on, oddly this time it didn't seem to make any difference how the car was being driven, (first time, it only seemed to come on when it was given a bit of welly) now it appears to come on at exactly 45.9 Km/h (see codes below).
    Took the car back to the garage and they did another Diagnostics scan and rest the codes. They said they were at a bit of a loss and suggested that I drove it to see how I got on, failing that take it to a main dealer. Driving home from the garage, yes you guessed it. Glow plug light came on.
    I've read so many posts on this, and I'm sure I read that an ECU update could potentially be a fix?
    Any help or advice would be greatly appreciated before I trundle off in limp mode to Audi to have my pants pulled down.
    Here are the codes:
    (As much as the Fuel pressure faults, I'm interested in the last two Faults (Address 02: Auto Trans U0100 and U0104) as these happened 250miles (2 days) before I bought the car)
    Address 01: Engine
    000387 - Fuel Temp. Sensor A (G81)
    P0183 - 001 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 84
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 714 /min
    Torque: 74.1 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0%
    Voltage: 14.36 V
    Pressure:475.7 bar
    Temperature: 84.6 oC
    0014195 - Fuel Pressure Regulation
    P1063 - 001 - Control Range Not Reached - Intermittent
    Freeze Frame:
    Fault Status: 00110001
    Fault Priority: 0
    Fault Frequency: 12
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 3024 /min
    Torque: 522.6 Nm
    Speed: 45.9 km/h
    Duty Cycle: 100.6%
    Voltage: 14.29 V
    Pressure: 205.9 bar
    Duty Cycle: 50.9%
    P1063 - 002 - Control Range Not Reached - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 12
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 3024 /min
    Torque: 522.6 Nm
    Speed: 45.9 km/h
    Duty Cycle: 100.6%
    Voltage: 14.29 V
    Pressure: 205.9 bar
    Duty Cycle: 50.9%
    P1063 - 004 - Control Range Not Reached - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 12
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 3024 /min
    Torque: 522.6 Nm
    Speed: 45.9 km/h
    Duty Cycle: 100.6%
    Voltage: 14.29 V
    Pressure: 205.9 bar
    Duty Cycle: 50.9%
    P1063 - 006 - Control Range Not Reached - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 12
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 3024 /min
    Torque: 522.6 Nm
    Speed: 45.9 km/h
    Duty Cycle: 100.6%
    Voltage: 14.29 V
    Pressure: 205.9 bar
    Duty Cycle: 50.9%
    P1063 - 003 - Control Range Not Reached - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 12
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 3024 /min
    Torque: 522.6 Nm
    Speed: 45.9 km/h
    Duty Cycle: 100.6%
    Voltage: 14.29 V
    Pressure: 205.9 bar
    Duty Cycle: 50.9%
    005488 - Engine Start Blocked by Immobilizer
    P1570 - 000 - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0%
    Voltage: 12.08 V
    Bin. Bites: 00000000
    Torque: 581.4Nm
    Readiness: 01000
    049408 - No Communication with Engine Control Module (SAE ECM/PCM)
    U0100 - 000 - - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 40
    Mileage: 147681 Km
    Time Indication: 0
    Date: 2064.00.00
    Time: 00:00:00
    Freeze Frame:
    RPM: 0 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 30.0
    (no units): 25.0
    Temperature: 72.0 oC
    T.B. Angle: 60.0%
    049412 - No Communication with Cruise Control Module
    U0104 - 000 - - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 40
    Mileage: 147681 Km
    Time Indication: 0
    Date: 2064.00.00
    Time: 00:00:00
  2. Re: Flashing Glow plug warning light - Limp mode - VCDS Codes - help
    46 Post(s)
    Ring Audi Customer Services on 0800 699 888 and see if there are any outstanding recalls for your car.
    I can only find 16567/P0183/000387 - Ross-Tech Wiki after a quick search, busy atm but will have a look later for you if you already haven't done so!
  3. Re: Flashing Glow plug warning light - Limp mode - VCDS Codes - help
    Feb 2007
    Thank you A6_Chris
    i'll give audi a ring in the morning. (Just rang them, and Don Warrington - rising damp - informed me that they are closed till 8am).
    I had a quick look on the VOSA website for recalls but could only find one for 2004.
    do you think it could it be the fuel temp sensor, causing the issue, and the other fault codes? This is a real learning curve for me, so apologies if I'm a bit slow getting to grips with this.
    thanks again.
    update:
    just rang Audi and there are no recalls on my car at all. : (
  1. 2006 2.0tdi glow plug light flashing and limp mode
    By ctm73 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-08-2016, 09:34 PM
  2. Glow plug warning / limp mode
    By longjohn1985 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-08-2013, 11:23 PM
  3. Glow plug light/limp mode
    By simonrk57 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-10-2012, 08:35 PM
  4. Please Help Flashing glow plug warning light/limp mode
    Last Post: 22-08-2012, 05:00 PM
  5. Question a4 tdi in limp mode and glow plug light flashing
    By iwa.r8 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2010, 12:33 AM
