Thread: Turbo whistling and slight dump noise....
  1. Turbo whistling and slight dump noise....
    Oct 2013
    Leeds
    Hello guys,
    my a3 is making some noises, my turbo wines like my other half and I get a psssssssst like noise when I drop my clutch to change gear through 1st 2nd and 3rd,
    my my birds dad recons my turbo is going to go ban at some point soon (I hope not)
    My motor is 2006 and has done 80k if that helps at all
    sebseb
  2. Re: Turbo whistling and slight dump noise....
    Has your budgie's father got Vcds?
    Any other symptoms aside from the moaning female noise, eg any cut outs, loss of power or reduced mpg?
    Sent from my Nexus 7 using Tapatalk 2
  3. Re: Turbo whistling and slight dump noise....
    46 Post(s)
    Engine code?
  4. Re: Turbo whistling and slight dump noise....
    Oct 2013
    Leeds
    It's not cut out at any point, can't say I've noticed a loss of power as it's been doing it since I got the car 4 months ago, mpg seems to be ok, a mate reckons it could be a boost leak somewhere?
    Not got a vcds, but got a mate who has. May have to go pay him a little visit this weekend to see If anything is amiss!
  5. Re: Turbo whistling and slight dump noise....
    Quote Originally Posted by Sebseb View Post
    If there was a boost leak, more often than not you'd be able to hear it.
    Check all the vac hoses (or ask your budgie's father to do it) and get a fault scan completed just in case.
  6. Re: Turbo whistling and slight dump noise....
    Feb 2010
    Cambridge UK
    Hello guys,
    sebseb
    What engine is it? Cars half that age have turbo whine so it's by itself fairly normal. Keep to regular oil changes, some long journeys, and let it cool towards the end of a drive and it should stay in the same condition for a long while. Your birds dad is kind of right, it will fail at some point, but same with any turbo. What seems like slight dump noise also common on the BKD engine and maybe others - it's probably clutch noise IMHO because one flaw is the clutch is hard to full disengage. If you fully let off gas and only then fully depress clutch (right to the bottom, hard as you can), do you still get the noise?
  1. Turbo whistling noise???
    By jasw in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-02-2017, 12:57 PM
  2. Question Slight whistling sound under acceleration
    By noetus in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-05-2013, 10:46 PM
  3. Question Turbo Whistling Noise
    By P4LI in forum Golf MK4 - 1999 - 2004
    Last Post: 08-10-2010, 04:31 PM
  4. Whistling Noise
    By bleasy in forum Golf MK4 - 1999 - 2004
    Last Post: 04-04-2009, 07:32 AM
  5. Whistling noise from n/s rear when changing gear.. Common noise in all PASSATS ??
    By Gaz_2005_Passat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-12-2008, 06:46 PM
