Thread: 1999 S3 Rear differential noise.
  1. 1999 S3 Rear differential noise.
    Sep 2008
    Morning All, I have been a member here for a while and found lots of good advise, so thanks for that.
    This current issue is proving rather difficult to resolve.
    For a long time now I have had a noise, which sounds like a worn bearing chnages with speed, no difference on over run, coming from my read diff.
    So far I have had it to 3 different garages all of which I trust and everone is saying the noise is coming from the diff, not wheel bearings or prop bearing etc.
    I removed the diff and Haldex unit, and sent to a very experiance mechanic( which I trust) who has repaired several diff's in the past but has not been inside one of these. After stripping the diff, the only problem he could find was one bearing was slightly ruff, which was replaced.
    I then put the diff and haldex unit back into the car, and it has made no difference whatsoever!
    Any know what could be causing this noise?
    Thanks in advance for any info.
  2. Re: 1999 S3 Rear differential noise.
    Sep 2008
    Hi All, So has this been covered already and I just cant find it on the site? or has no one any idea?
  1. Please Help 2.8 1999.5 110k - driver side rear noise
    By ihartley in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-01-2012, 09:49 PM
  2. Rear Differential Noise
    By Duncster89 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-07-2011, 01:27 PM
  3. Attention Rear Differential Specifications
    By Quattros in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-11-2010, 01:15 AM
  4. Question Suspect gearbox/differential noise
    By Russell8 in forum Touran - Sharan - Caravelle
    Last Post: 11-11-2008, 06:31 AM
  5. 1999 A6 - Rear Noise Driving Me Mad ! HELP
    By bradspaul in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-07-2007, 11:13 AM
