Thread: re-installing rear lights
  1. re-installing rear lights
    Dec 2012
    East Sussex
    Evenin' all - just thought that I would share a top tip when putting the rear lights back in on an A6 Avant (and my sincerest apologies if this is a well know workaround).
    In the process of migrating from one Audi to another so thought that I would be a smart *** and remove the rather expensive rear LED light clusters I had fitted when I bought the car and maybe sell them (PM if interested - if that is allowed?) and found a clever little online guide to show a bit of a technophobe how to do it.
    All worked great until I tried to refit the inner rear lights - the ones in the tailgate section. They are a total badgers backside to get back in with the larger of the two brackets needing countless movements to try and get it in line whilst trying to shine the head torch in and bend over backwards to see what you are doing!
    The answer came to me but mistake - the small nut on the bracket is set into a little flange to keep it in place - well it pinged off, didn't lose it but without it on the bracket slotted into place as easy as you like.
    Sadly for me, it took me another hour of cursing to realise that this was a good thing so took the nut off the second bracket and hey presto! Anyways, hope it might help someone else one day save an hour or two!!!
    2007 A4 Avant 2.0TDI S Line
    1 1 0
  2. Re: re-installing rear lights
    Feb 2009
    Glasgow UK
    I read your post with interest even though I have a saloon.
    I'm sure it'll help other members.
    Just one point - If you can please edit your post to create Line breaks between lines, it'll make it much more appealing to read, usually when I see large block text I switch off.
    Edit - Nice one, thank you
    Thanks for posting.........
  1. Question Installing HID Lights - 07 tdi 170 bhp
    By pgblues in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-10-2012, 05:15 PM
  2. Please Help Installing front fog lights
    By tpl288 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-02-2009, 03:36 PM
  3. Please Help Installing aftermarket daytime running lights
    By jasrajpal in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-07-2008, 10:46 PM
  4. Installing Fog Lights Into Golf MK5 STD
    By irishgolf in forum Golf MK5 - 2004 - 2009
    Last Post: 29-04-2008, 09:14 PM
  5. Installing blue interior lights, advice req.
    By bcam in forum Passat - Archive Topics
    Last Post: 11-02-2008, 12:30 AM
