Thread: G61 Knock Sensor connector location
  1. G61 Knock Sensor connector location
    warp_speed Guest
    Hey people, quick question. Can someone tell me where the G61 knock sensor connector is located. I changed my thermostat yesterday and I think I might have sprayed water on the connector and I'm now getting a low signal fault being thrown.
    I can see the sensor located underneath the inlet manifold near the timing belt end but the cable flows away underneath the manifold and I cannot see where the end connector is. Is it part of the main connector above the oil cooler? I need to use some contact cleaner to get rid of any water that might be there to resolve my fault.
    Engine is 2.0TFSI BUL engine.
    Thanks in advance for any help
  2. Re: G61 Knock Sensor connector location
    warp_speed Guest
    OK, managed to sort it, the sensor is right behind the thermostat and was saturated with coolant when I replaced the thermostat. The connector is on the knock sensor itself, you would have to remove the thermostat again to get to it, but managed to seperate the connector enough to spray contact cleaner in it, clipped it back on and good to go. Anyway thought I would share the knowledge
  1. OBD2 Connector Location
    By A8pete in forum A8 - S8 - V8
    Last Post: 16-03-2011, 04:42 PM
  2. Question Pre wired Cd Changer connector location
    By benw1984 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-04-2009, 09:01 AM
  3. Help Location Of Big Connector In The Back Of Cluster
    By Don_passat98 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2008, 06:49 AM
  4. Vag Com Diag Connector Location??
    By Pernicitus in forum Golf MK4 - 1999 - 2004
    Last Post: 30-12-2007, 05:04 PM
  5. location of VAG-COM connector
    By guy1 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 07-05-2007, 12:45 PM
