Thread: Turn Signal Change
Results 1 to 10 of 12
  1. Turn Signal Change
    Jul 2013
    76 Post(s)
    How do you change the comfort rate of the turn signal on a A6 Facelift?
    Is it done by the Hidden Menu?
    Dan
  2. Re: Turn Signal Change
    Feb 2013
    Gloucester
    57 Post(s)
    What does changing the comfort rate do? Change the speed the indicators flash?
  3. Re: Turn Signal Change
    Sep 2013
    Measham, UK
    i think he means the amount of pressure needed to activate it, but I wasn't aware that it could be changed?
    Audi A6 2.0 TDi S-Line Special Edition (60 Reg) Phantom Black
  4. Re: Turn Signal Change
    Jul 2013
    76 Post(s)
    I want to change the rate from 3 blinks to 5.
  5. Re: Turn Signal Change
    Sep 2013
    Measham, UK
    Again, don't know tbh. Maybe something in VCDS?
  6. Re: Turn Signal Change
    Feb 2013
    Gloucester
    57 Post(s)
    Ah, for the one touch operation? Didn't know it could be changed.
    Sent from my iPhone using Tapatalk - now Free
  7. Re: Turn Signal Change
    Jul 2013
    76 Post(s)
    It can be done on an 2010 octavia via the 09 cent elect module adaptation.
    I tried this, but i could not find this option on my A6.
    Dan
  8. Re: Turn Signal Change
    Sep 2013
    Measham, UK
    It's not one on the tweaks list, but it doesn't mean that it's not possible. Maybe if A6_Chris or someone with a little more know how see your post they can guide a little better. It might be a certain byte needs tweaking?
  9. Re: Turn Signal Change
    46 Post(s)
    Yes it's possible, I'm getting my lunch but will be back home about 3pm so I'll have a look then if someone hasn't done so.
  10. Re: Turn Signal Change
    46 Post(s)
    Okay so after looking I can't seem to find it on a prefacelift.
    However other (lesser!) cars have the feature in the the 09 Cent Elec module, adaption (10) menu.
    Checked my facelift A3 and it's there so this is where I maybe got confused between the both.
    I'll continue to look but could facelift owners check the above?
  1. Turn signal problem???
    By knight A4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-02-2009, 09:38 PM
  2. Turn signal problem
    By a6rob in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-04-2008, 04:52 PM
  3. Front Right Turn Signal
    By randyrich86 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-03-2008, 11:05 AM
  4. Turn signal problem on S3
    By noodamo in forum Audi A3 - Archive Topics
    Last Post: 11-01-2008, 03:09 PM
  5. Turn Signal Indicators
    By WesleyP in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-09-2007, 10:51 AM
