Thread: Enabling Auto Ride-Height: 2001 Allroad
  1. Question Enabling Auto Ride-Height: 2001 Allroad
    Feb 2013
    Austra
    Hi All,
    When I first got my Allroad it correctly adjusted the ride height dependant on my speed. It has now decided that it will only do the lowering from Level 3 to Level 2 at above ~80km/h but when I slow down it stays at Level 2 instead of going back up to Level 3 as it used to.
    Manual height adjustment works no problem.
    Is there a button combination I have accidentally pressed that disables the Auto Ride-Height?
    Thanks,
    Des
    2001 - A6 Avant 2.5 V6 TDi C5 Engine: AKN Gearbox: DQS (6S)
    2001 - A6 Allroad 2.5 V6 TDi C5 Engine: AKE Gearbox: FTH Final Drive: ENX
    2004 - T4 Syncro SWB
    Full Licence Ross-Tech VCDS
  2. Re: Enabling Auto Ride-Height: 2001 Allroad
    Ayrshire, Scotland
    18 Post(s)
    if you have the early allroad you will find where the 4 level green lights are there is an orange MAN light,
    if you have this, you have the option to switch from manual to auto (Manual, which will not go back the the pre-requested height)
    press and hold the up arrow for 2-3 seconds to switch from MAN to auto.
    if you dont have this MAN light then it suggests the system is low on pressure and cannot lift it back yup when parked
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: Enabling Auto Ride-Height: 2001 Allroad
    Feb 2013
    Austra
    Hi Andy,
    Having installed one of your fine pump repair kits I know there is no lack of pump power!
    As I mentioned, the car will change heights perfectly correctly when I press the up or (less surprisingly) the down button. What it won't do is go back to Level 3 from Level 2 when I slow down to below ~80Km/h.
    It used to do this and I was wondering if I had inadvertently disabled the "auto" function?
    I look forward to further suggestions.
    Cheers,
    Des
  4. Re: Enabling Auto Ride-Height: 2001 Allroad
    Ayrshire, Scotland
    18 Post(s)
    Hi Des, re read my post above do you have the orange MAN light?If so this allows you to disable, enable Auto moderegardsAndy
  5. Re: Enabling Auto Ride-Height: 2001 Allroad
    Feb 2013
    Austra
    Hi Andy,
    No, sadly I have no "MAN" light or button ...
    I had the impression that when I first got the car that it would work on automatic until I manually changed ride height. After doing so the automatic rise function wouldn't work, although the lower function above ~80km/h would always work. Stopping the car, turning off the ignition and re-starting would re-activate the automatic ride height control. This no longer happens.
    Also, I wondered if at some point I had inadvertently disabled the function through some "secret" sequence of rise - lower button presses ...
    If there is no such combination I have a full licence Ross-Tech system so I could investigate any settings if only I knew where to look! Is there a soft setting for this function do you know?
    Thanks for your help,
    Des
  6. Re: Enabling Auto Ride-Height: 2001 Allroad
    Aug 2007
    Midlands, Uk.
    Quote Originally Posted by Dr_Des View Post
    Hi Andy,
    Des
    I thought the normal position was level 2, at speeds greater then 85mph ish the suspension drops to level 1, then at speeds lower than 30mph back up to level 2, at least this is how mine behaves.
    I have no manual light, but if I set a position ie. level 1, this will last until I go above the 85mph threshold and back down again (even if there is a key off etc), the suspension will again revert to its normal level 2, appearing to override the manual selection.
    The only change you can make to this behaviour is the base ride height with the 402 mod.
    Regards,
    Allan.
  1. Drive select in auto and ride height
    By diecastsink in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-06-2013, 10:33 PM
  2. Ride height ?
    By nskeates in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-06-2010, 08:03 PM
  3. Ride height
    By 808 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-05-2009, 03:21 PM
  4. ride height
    By chris m in forum Alhambra
    Last Post: 17-04-2009, 07:37 PM
  5. Ride height
    By Red Avant in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-10-2008, 04:51 PM
