Thread: A how-to with some VAG-COM modules
Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
  1. Re: A how-to with some VAG-COM modules
    #41
    Mar 2010
    Bangalore, India
    Quote Originally Posted by Marco34 View Post
    Since getting a genuine Ross-tech cable I've been able to make a few changes to my car that work successfuly. With all the info on the web I thought I would note them down here for anyone who wants to make quick changes without trolling the web.
    If some are obvious then apologies. It has simply allowed me to make the car more functional to how I would like it.
    Ross-tech HEX-COM cable serial interface on a 2001 A4 1.9TDI
    First change I made was to the service intervals. I wanted 6 months or 5,000 miles as I like to drain the oil that frequently on the TDi. Note the values in bold I have changed and are personal preference.
    After launching VAG-COM select the following:-
    17-Instruments - Adaption-10 - Ch No. 42 Oil in 1 - min value 5
    43 Oil in 1 - Max vaule 5
    44 Insp 1 - Max days 182 (6 months)
    There is plenty of talk re MPG and mine was very optimisitc. I calculated the true MPG and took a percentage difference. It was about 10% optimistic! Why have a DIS that shows incorrent miles left and average consumption. I've changed this:-
    17 - Instruments - Adaption-10 - Ch No. 3 - Origininal val 100 (this is a %) my new value is 110. Use TEST and see Average MPG drop in DIS!
    I also wanted central locking at speed. This requires some calculation in Binary mode, but very easy.
    46 - Central Conv - Coding-07 - Original Val 6859 New Val 6891
    The following codes were active on my car. I simply added 32 to the orginal value and the doors now auto lock. Equally, by removing a Binary for the total value you would disable that function.
    BinaryFunction 1GB Alarm
    2 Anti theft warning bleep
    8 Anti theft warning system
    32 Auto Central Locking at 15 mph
    64 Comfort function via remote control
    128 Right hand drive
    512 Confirmation close via remote
    2048 Door/Window regulator logic
    4096 Thatchem anti-theft warning
    Hope this may help some of you. As I said, it is documented throughout the internet but we may as well build up a database of common changes that are easy to locate.
    Regards
    Mark
    Hello,
    i really do not know whether am completely off the topic, but i thought asking you considering your know-hows, would be better to post here.
    i have a skoda ocatavia II with edc16 1.9tdi pd.
    there was a problem with im*o, so i turned off the im*o using edc16 calc.
    now my new problems are;
    1. when i turn on the ignition key, the cluster gives a warning message "im*obilizer adjustment failure" and also the car with key light blinks...all this messages goes off when i start the car. but how to get rid of this message and car with key warning light?
    2. after turning off this im*o in the ecu, my central locking system has stopped working!!! how can i get this central locking system back to work?
    i have vagcom 8.05 version.
    please suggest what to do? please help!
    regards,
  2. Re: A how-to with some VAG-COM modules
    #42
    Mar 2010
    thornton cleveleys uk
    hi all, newbie here.
    just had a prob with brake switch on passat trendline 05. showed up as abs fault and wire light kept flashing
    fixed it and all warning lights have gone off
    would i need to get into the ecu for any reason.
    where would one buy a connection to the port.
    i have seen some on e bay, but i assume they are just the connection.
    is the programme expensive.
    had the car week now and getting used to it.
    cheers rodders
  3. Re: A how-to with some VAG-COM modules
    #43
    Canada
    Quote Originally Posted by rodders68 View Post
    No, a fault code will be logged but not effect performance
  4. Re: A how-to with some VAG-COM modules
    #44
    Jul 2010
    Leicester
    Can anyone tell me where to get the codes from?
    Also Marco how do you know wot codes to input and how do you know what they will change? Is there a book or something?
  5. Re: A how-to with some VAG-COM modules
    #45
    Southern County Softy
    20 Post(s)
    Have a look at the ross tech wiki
    A4 2.5 tdi QS (mapped)
  6. Re: A how-to with some VAG-COM modules
    #46
    Jul 2010
    West London
    Hi all,
    I have a code of 07151 on my B7 A4 avant.......what does this mean i have turned on? or can turn on?
    2007 A4 Avant 2.0TDi S-line Quattro (BRD)
    170BHP/Voltera Leather/ Colour DIS/Armrest/Privacy Glass/ Concert + IPOD with BOSE/GSM phone prep
  7. Re: A how-to with some VAG-COM modules
    #47
    May 2010
    Nokia, FI
    Hi all,
    Is there any changes to get rid off the bulb checking from Audi A4 2007?
    And Is there any "hidden" setup menus in FIS? in this high instument cluster...
    Thanks for all answers.
  8. Re: A how-to with some VAG-COM modules
    #48
    Nov 2016
    US
    Does anyone know what module the power to the seats would be in? I somehow disabled my seat power.
    Sent from my SM-G920V using Tapatalk
  1. Diesel Power Modules
    By ½cwt in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-03-2007, 05:55 PM
  2. Diesel Tuning Modules
    By hedropsforglory in forum Chat - Completely Off Topic
    Last Post: 26-01-2007, 09:20 PM
