Thread: Electrical Gremlins?
  1. Electrical Gremlins?
    Jun 2008
    Kent
    Driving the car today and noticed it was not showing the radio station that was playing above the electronic speedo.....same when playing from an SD card. Then found the left hand buttons on the steering wheel were also not working (mode, scroll bar and voice activation) and then also Bluetooth wasn't working. Stopped the car and switched off all exactly the same. Drove for 40 miles and then left the car for a couple of hours and when starting again all was working fine. Done a scan and can't see any issues....going to get it booked in as it is only 10 weeks old, but wondered if anyone else had seen this?
    Chassis Type: 8K (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72 77
    Mileage: 5580km/3467miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CNCD) Labels: None
    Part No SW: 8T2 907 115 HW: 8T2 907 115
    Component: 2.0l R4 TFSI H13 0003
    Revision: --H13---
    Coding: 0A2500322427010B2000
    Shop #: WSC 06208 000 00000
    ASAM Dataset: EV_ECM20TFS0218T2907115 001004
    ROD: EV_ECM20TFS0218T2907115.rod
    VCID: F5E53E845407FEB62EB-80A0
    1 Fault Found:
    17178 - Databus
    U1123 00 [032] - Received Error Message
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 0
    Reset counter: 0
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    Readiness: 0000 0000
    Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
    Part No SW: 8K9 927 156 C HW: 0B5 927 156 J
    Component: 0B5 20TFSIRdW H02 0003
    Revision: --H02---
    Coding: 000001
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_TCMDL501021 001015
    ROD: EV_TCMDL501021.rod
    VCID: 3D7566A4ACB7E6F6A6B-8068
    1 Fault Found:
    18147 - No Communication with Engine Control Module (SAE ECM/PCM)
    U0100 00 [032] - -
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 0
    Fault Frequency: 0
    Reset counter: 0
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 CD HW: 8K0 907 379 CD
    Component: ESP8 quattro H09 0050
    Revision: -------- Serial number: --------------
    Coding: 31154401
    VCID: 7DF5A6A4E43726F6E6B-8028
    No fault code found.
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 GF HW: 8K0 907 064 FF
    Component: BCM2 2.0 H12 0633
    Revision: 00002001
    Coding: 05B14040000000000000
    VCID: 7AFFADB8F51911CEC39-802F
    Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
    Component: J764 ELV MLB H40 0046
    Address 08: Auto HVAC (J255) Labels: None
    Part No SW: 8K2 820 043 S HW: 8K2 820 043 S
    Component: KLIMA 3 ZONEN H04 0121
    Revision: D0000000 Serial number: 01030620131910
    Coding: 642402C000
    VCID: 397D72B4B09FDAD68A3-806C
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 DG HW: 8K0 907 063 DG
    Component: BCM1 1.0 H16 0103
    Revision: 07016001 Serial number: 00000621171702
    Coding: 260080148034AFC00081400000001D0D4F1D43082709020100 0008004400030100000024000000
    Shop #: WSC 06325 123 12345
    VCID: 77F9B48CC60B0CA6BC7-8022
    Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 030613 H06 0080
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
    Component: G397_RLFS H06 0002
    Coding: 02005D
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
    Component: AirbagVW-AU10 H47 0610
    Serial number: 003KFDB03P6A
    Coding: 30534235363030303030554A3052384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 489B0770F375B35E05D-801D
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME7A055A5BQ
    Crash sensor for side airbag; passenger side:
    Serial number: 6344MSME79652D54P
    Crash sensor for side airbag; rear driver side:
    Serial number: 6352QSME5D310778L
    Crash sensor for side airbag; rear passenger side:
    Serial number: 6362QSME363E2B68V
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME39313178Y
    Crash sensor for front airbag; passenger side:
    Serial number: 63832SME39312B4E4
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
    Component: Lenks.Modul H02 0171
    Revision: 00000000 Serial number: 20130606000093
    Coding: 000036
    VCID: 4FA92C6C1E1B6466447-801A
    Component: E221 - MFL H03 0004
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 983 E HW: 8K0 920 983 E
    Component: KOMBIINSTR. H35 0563
    Revision: 00400000 Serial number: WWB7CM95E
    Coding: 238F090002012600010000
    VCID: 3779748C868BCCA67C7-8062
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8R0 907 468 L HW: 8R0 907 468 A
    Component: GW-BEM 5CAN H11 0056
    Revision: 1V080027 Serial number: 2741V135218297
    Coding: 80CF07FF00
    VCID: 489B0770FB75B35E05D-801D
    Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
    Component: J367-BDMHella H03 8041
    Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
    Component: J532_DCDCStab H05 0006
    Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
    Part No SW: 8T0 035 785 A HW: 8T0 035 785
    Component: SG ext.Player H08 0290
    Revision: 00000000
    Coding: 020202
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
    Component: TSG FA H09 0305
    Coding: 011C12205C01410001
    VCID: 56A7D90821C115AE871-8003
    Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
    Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
    Component: RCEPS H37 0507
    Revision: 00001000 Serial number: 0031544019
    Coding: 100000000001
    Shop #: WSC 06324 000 00000
    ASAM Dataset: EV_RCEPSAU48X 008014
    ROD: EV_RCEPSAU48X.rod
    VCID: 346343809FFD27BE595-8061
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0307681947
    Coding: 011B0E2280B900818130013680000047
    Subsystem 1 - Part No: 8K0 951 177
    Component: DWA-Sensor H02 0040
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Address 47: Sound System (J525) Labels: 8T0-035-223-BOC.clb
    Part No SW: 8T1 035 223 HW: 8T1 035 223
    Component: DSP Prem H05 0040
    Revision: 00005001 Serial number: 94803015393801
    Coding: 0203010302
    VCID: ECD31BE00F4D3F7EC15-80B9
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
    Component: TSG BF H09 0305
    Coding: 011C12205E01410001
    VCID: 55A5DE043CC71EB68EB-8000
    Address 53: Parking Brake (----) Labels: None
    Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
    Component: EPB-4 H01 0004
    Revision: -------- Serial number: 10000000223926
    ASAM Dataset: EV_ParkiBrake 001028
    ROD: EV_ParkiBrake_AU48.rod
    VCID: 397D72B4B89FDAD68A3-806C
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8R2 035 186 P HW: 8R2 035 186 P
    Component: Concert3 DAB H06 0470
    Revision: 00000002 Serial number: AUZ5Z6M1906975
    Coding: 0403008201018D00835B071800
    VCID: 4381105CC2539006D0F-8016
    Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
    Component: Display
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
    Component: TSG HL H07 0305
    Coding: 010C12204001210001
    VCID: 59BDD23450DF3AD6AA3-800C
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
    Component: TSG HR H07 0305
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8T0 862 335 F HW: 8T0 862 335 E
    Component: FSE_256x BT H45 0660
    Revision: 00000000 Serial number: 00000005652470
    Coding: 0010320
    VCID: 3D7566A464B7E6F6A6B-8068
    Glacier White B8 Black Edition 2.0T Fsi quattro stronic - Advanced Key, Nappa Leather, Electric Folding Mirrors, Interior Light pack
  2. Re: Electrical Gremlins?
    46 Post(s)
    Sometimes the radios just get confused, my A3's Concert did this the odd time before replacing with RNSE.
    If it happens again just do a reboot, I think for non-mmi radios its SETUP + Centre rotary knob + upper right inner key .. hold for a few secs and release.
  3. Re: Electrical Gremlins?
    Jun 2008
    Kent
    Thanks I'll try that next time
  1. electrical gremlins
    By Alaska in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-04-2013, 01:31 PM
  2. Please Help Electrical Gremlins!
    By acmo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-09-2011, 04:53 PM
  3. Electrical gremlins
    By mboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-04-2011, 08:40 AM
  4. audi electrical gremlins
    By rev-ian in forum New Member Introductions
    Last Post: 29-09-2008, 10:20 PM
  5. Electrical gremlins
    By brighton123 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 09-04-2008, 11:06 PM
