Thread: Strange rear light failure warnings
Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
  1. #41
    Nov 2012
    North Somerset
    Did you try a new bulb?
    Reversing lights won't affect your mot iirc.
    TBH no but the bulb looks intact I'll try it with the O/S bulb tomorrow as far as MOT goes, I'm sure if it's got two reversing lights they should both work
    Any MOT testers on here Crasher Zollaf ??
    Quote Originally Posted by Brycie View Post
    Mine passed it's MOT today too. The guy that did it, failed it due to a cut in the tyre, but when I challenged it with the Manager, he overruled the fail & issued the pass certificate .
    Back on topic, My Dad got stopped by the Police for having one reverse light out & he said that it's not part of the MOT & it had just passed. Their reaction was to tell him that that didn't matter, if it's fitted, it should be working. I bet Gupsterg could provide some useful info/diagrams if you contacted him Chadders.
    No advantages mate not worth my pension
    A6 C6 Avant TDI, de-Badged, LED side lights, LED numberplate lights not just bulbs! so far!!
  2. Re: Strange rear light failure warnings
    #42
    Mar 2011
    Clitheroe, England
    11 Post(s)
    Well that's no good. There should be some perks to every job.
    Sent from my GT-I9300 using Tapatalk
    The Only Way Is A6!
  3. Re: Strange rear light failure warnings
    #43
    Nov 2012
    North Somerset
    Cheers I did PM the other day just to say Hi etc but he's not replied I'll text him I know he's been busy moving
  4. Re: Strange rear light failure warnings
    #44
    46 Post(s)
    apparently its a blue/red wire, if not let me know and i'll look again
  5. Re: Strange rear light failure warnings
    #45
    Nov 2012
    North Somerset
    There is a blue and red wire on the side that's affected but not on the O/S
  6. Re: Strange rear light failure warnings
    #46
    Nov 2012
    North Somerset
    Well this morning I've removed the tailgate trim and the light cluster affected absolutely nothing to go on. At the point where the wiring to the light cluster enters the tailgate it's all intact nothing trapped cut or frayed all in place as if it had been put in yesterday the light cluster was clean and dry and fitted nice and snug the multipoint plug to bulb holder its self is clean and fits nice and tight all the wiring is in tact. The old bulb holder is identical to the new one as in there's no corrosion or broken solder etc.
  7. Re: Strange rear light failure warnings
    #47
    Nov 2013
    South Wales
    Hey guys. Just wondering actually, those of you who have drilled holes in your light casing for the condensation issue, what kind of size holes are we talking here? Teeny Tiny, or fairly substantial? Anyone got any pictures lying around of the work they did, just to give an idea?
    Craig
  8. Re: Strange rear light failure warnings
    #48
    46 Post(s)
    Massive thread here A6 Rear light cluster ( 07)
  9. Re: Strange rear light failure warnings
    #49
    Mar 2011
    Clitheroe, England
    11 Post(s)
    I probably drilled about 7 or 8 holes per cluster using something like a 4mm drill bit - roughly. Just enough to create circulation.
    The Only Way Is A6!
  10. Re: Strange rear light failure warnings
    #50
    Nov 2012
    North Somerset
    Mark TM helped out today and scanned with VCDS showed a fault with the earth not connecting can't quite remember the exact wording now. Anyone have any idea where the wires might run from and where the earth might be
  1. Replies: 7
    Last Post: 11-08-2012, 10:13 AM
  2. Rear Light Failure
    By racey52 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-02-2012, 06:58 PM
  3. Bulb failure - random warnings after replacing bulbs with LEDs
    By rosso rocket in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-11-2011, 12:43 PM
  4. Strange Bulb Warnings
    By jayandmaz123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-10-2009, 07:30 PM
  5. Touran rear light failure
    By TQgrump in forum Touran - Sharan - Caravelle
    Last Post: 30-12-2008, 04:25 PM
