Thread: DPF Removal anyone?
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. DPF Removal anyone?
    Mar 2012
    just wondering about this. I have 2011 golf match 140 2.0 tdi. I do mainly short journeys with occasional longer one twice a week. Intending keeping the car a long time and wondered if anyone had had this done and what results. I am not interested in chipping the car to go faster as the engine as it stands is fine, but i think software needs modified if DPF removed. I am in Scotland. Or do you just wait until the DPF needs replaced and then remove it?
  2. Re: DPF Removal anyone?
    Feb 2012
    Ipswich, Suffolk
    I'd be interested in knowing about this as when it does fail I'd like to remove it.
    mk6 Golf. Graphite Blue. 1.6 TDI. All Factory Standard. Less Than 30,000 Miles.
  3. Re: DPF Removal anyone?
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    There are tuning companies that do the DPF removal. It isn't just a matter of removing the DPF they write to the ecu to disable the sensors else you will have the MIL light flashing, Google them.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  4. Re: DPF Removal anyone?
    May 2008
    London, UK
    Not recommended as the department of transport consider it illegal, and it's possible in the future will cause MOT failure. You would have been better of buying a petrol Golf
  5. Re: DPF Removal anyone?
    Sep 2009
    12 Post(s)
    That's a debatable whether if would fail an MOT with the DPF removed as diesels are only tested for smoke not emissions. I used to have an MOT testers manual which you can download but I've lost the link now.
  6. Re: DPF Removal anyone?
    May 2008
    London, UK
    Yes but it is quite possible they'll change the MOT test requirements in the future and you'll end up with all these modded diesels failing the MOT due to a removed DPF. Like what happened recently with airbag and ESP lights etc becoming a failure item, and aftermarket xenons. You're increasing emissions however you look at it, they are fitted for a reason. Its almost as daft as the people who remove AC to improve performance.
  7. Re: DPF Removal anyone?
    Beddoe Guest
    There is an article about this in Auto Express, issue 1294, 13-19 November 2013, page 16 and 17. Essentially, because it's a modification, you should inform your insurance company. One or two companies would apparently decline cover.
  8. Re: DPF Removal anyone?
    Pembrokeshire
    22 Post(s)
    https://www.gov.uk/government/upload...s-guidance.pdf
    if the dpf is fitted as a requirement for the vehicle to pass the euro emissions level, then removal of it is illegal. so from 2008, euro 6 iirc, you can't remove a dpf. prior to this most cars didn't need the dpf to meet the relevent euro emissions, so you can remove it. after 2008 your car may still pass an mot as this is only a smoke test that the dpf doesn't affect but it wouldn't pass a proper emissions test.
    this is how i interpret the rules.
  9. Re: DPF Removal anyone?
    Aug 2011
    Meath
    Seems pretty clear to me!
  10. Re: DPF Removal anyone?
    Pembrokeshire
    22 Post(s)
    yeah, basically if you don't like it, get a petrol engined car. it does seem that a lot of people will tell you its fine to remove it as the mot doesn't test for it, but they are the ones charging to remove them.
  1. DPF Removal
    By Chipsteruk in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-04-2013, 05:44 PM
  2. Dpf removal company
    By sabb in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-07-2011, 09:43 AM
  3. A4 170 DPF Removal
    By m7rcu in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-06-2011, 12:18 AM
  4. Question DPF Removal
    By spanglish9978 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-05-2011, 11:15 AM
  5. DPF Removal
    By aveling in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-04-2011, 11:13 AM
