Thread: Heater issue.
  1. Heater issue.
    simyboye Guest
    When my heater is on cool it blows out slightly warm air but the main problem is the fan blows quite well then no so. Is this a worn out bushes issue on the fan?
    In VCDS i have an error heater locked
    Address 18: Aux. Heat Labels: None
    Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
    Component: Heizgeraet H07 0110
    Revision: 0000000C Serial number: 00000009006406
    Coding: 0000001
    Shop #: WSC 00000 000 00000
    VCID: 1A306502D548AFC8CF1
    1 Fault Found
    02251 - Heater Unit Locked
    000 - -
    Any ideas?
  2. Re: Heater issue.
    46 Post(s)
    You'll start and use the rosstech wiki pretty often - 02251 - Ross-Tech Wiki
    When found in Aux Heater module of Audi A8 (4E), unlock heater module by saving a 1 in Adaptation Channel 007, then clear fault codes.
  3. Re: Heater issue.
    Sep 2009
    NW England
    Quote Originally Posted by simyboye View Post
    Any ideas?
    Do you mean the fans blows strongly then slows down?
    If that is what you're experiencing, then its working perfectly. The system really works around the temperature you've chosen, it will work hard to get it to that temperature, then once its at the right heat, it slows down to keep it at that temperature.
    This is a really smart system, the best way to use it is to set it to a temperature you find comfortable, then leave it on auto and it will look after you.
    I had a girlfriend that used to fight the system, she'd set it to 16 degrees, so the system would throw really cold air at her, because she'd asked to be really cold. Then she'd winge about the cold air and shut off the face vents, so it would shift all the cold air to the footwells, still trying to make her cold like she'd asked. Then she'd put her feet on the seat because they were cold. I used to tell her to set it to 22, but she'd say 16 isn't cold, and she doesn't like to be hot in a car. Eventually I set the house thermostat to 16 in the winter and asked her if this was a nice comfortable temperature for her. Finally she got it, and then set the temperature on her side to 21, that was actually the temperature she wanted.
    2006 A8 4.2 | Adaptive Cruise | Bose | BT | Pwr Doors | Satin Nappa Lthr | 20" Alloys
    Xenon Plus | Analogue & Digital TV | Comfort Seats | Sport Suspension
    Heated MFSW with paddles | Solar-Panel Sunroof | Electric Rear & Side blinds
    Heated F&R seats | Auto Boot Lid | 1-touch Mem | Advanced Key | Inside & Outside lighting pckge
    Retrofitted |Towbar |Rev+Front Cam |
    MMI 5570 |AMI |2014 Maps |Illuminated sills |RSE |S8 CF Trim |TPMS
  1. b6,1.8t AVJ,5 SPEED MANUAL COOLANT/HEATER ISSUE
    By fourringsrus in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-11-2014, 10:17 PM
  2. VW sharan Heater issue
    By saville in forum Touran - Sharan - Caravelle
    Last Post: 10-04-2013, 10:11 PM
  3. Heater Issue
    By fit4free in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-03-2011, 12:26 AM
  4. Coolant leak / heater issue
    By Steve2.7T in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-12-2009, 12:03 AM
  5. Air Con and Heater Issue
    By hobbes40 in forum Audi A3 - Archive Topics
    Last Post: 29-06-2007, 11:27 AM
