Thread: Audi A6 S line 2014 usb port ???
  1. Audi A6 S line 2014 usb port ???
    Sep 2013
    ENGLAND
    Would anyone know whether the new A6 S Line 2014 have its own usb port ?
    Thanks.
  2. Re: Audi A6 S line 2014 usb port ???
    May 2013
    Cheshire
    11 Post(s)
    My SE has the tech pack and there's only the AMI port. I think it must be the same for the S line
    63 reg Ibis White A6 2.0 TDI SE Multitronic, Tech pack, folding mirrors, rear view camera, heated seats.
  3. Re: Audi A6 S line 2014 usb port ???
    Sep 2013
    Malton, UK
    Without the tech pack you have a 12V power outlet in the storage space under the centre armrest. Plug a USB adapter into that.
  4. Re: Audi A6 S line 2014 usb port ???
    Apr 2009
    Surrey
    182 Post(s)
    Quote Originally Posted by mrloxley View Post
    Thanks.
    Depends what you want it for. If it is to charge a phone then A ScottyA6 says there is a 12v socket in the arm rest which you could plug a USB adaptor into. As standard it also gets a 3.5mm input jack in the armrest for music devices but this of course does not give you MMI control over what you are playing. If it is to play music then you need to spec AMI and this comes as standard with two cables, one for Apple devices and one to plug a USB cable into for other MP3 players and storage device. As an alternative the car comes as standard with 2 SD card sots, one is used for Navigation and the other is free for music or videos.
  5. Re: Audi A6 S line 2014 usb port ???
    May 2013
    Cheshire
    11 Post(s)
    Quote Originally Posted by ScottyA6 View Post
    In the central arm rest, there is of course also that 12V point as well. I have a USB adapter in it which charges my phone while the AMI powers / manages the 2.5 HDD with all the music.
    FYI there is also (at least) one other 12V at the rear of the armrest, facing the back seats (you get 2 if you spec the storage pack I think)
  6. Re: Audi A6 S line 2014 usb port ???
    Mar 2008
    Warwickshire
    You can get quite nice low profile 12v car->usb adapters now that provide 2 USB ports @1A and mount (fairly) flush to the 12V socket. Quite cheap on ebay on a few quid.
    Audi A6 (C7) 3.0 TDI S Line Quattro 245 Daytona Grey Sep 2013 -
    Audi A4 (B8) 2.0 TDI SE 143 Lava Grey 2008 - 2013
  7. Re: Audi A6 S line 2014 usb port ???
    Mar 2008
    Warwickshire
    Quote Originally Posted by belly buster View Post
    Having done a little more research, the cheaper ones can be a problem. Belkin do a genuine 2.1A adapter, Griffen do a 1.0A adapter; there are a fakes out there so just be careful when buying.
    I've ordered a Belkin one for 18.99 with a lightning (ipad 4) cable so will report back once arrived.
  1. hard wired USB port.
    By sam.bird3 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-06-2013, 10:52 AM
  2. RCD-310 and need for USB port
    By teodor_ch in forum Golf MK6 - 2009 - 2013
    Last Post: 09-09-2009, 11:02 AM
  3. USB port
    By TheDufster in forum Passat - Archive Topics
    Last Post: 04-01-2007, 01:23 PM
  4. Passat USB port
    By Haji_Doc in forum Passat - Archive Topics
    Last Post: 14-11-2006, 12:46 AM
  5. Advise about usb port
    By snawaz in forum Passat - Archive Topics
    Last Post: 25-10-2006, 10:22 PM
