Re: Audi tt 225 quattro 2002 Help needed flashing orange car with key on dash –
04-10-2013,10:15 PM
I'm afraid you've had an idiot working on your car. There are a few reasons why the brake (pad) warning light would remain on the dash after the brakes were 'done'. I wouldn't start looking behind the dash first though...
Can you confirm the pad wear indicator was showing (O) or the fluid level - which is a red symbol? If pad wear, all of the wear sensors and wiring have to be complete, good continuity and free from earths for the light to extinguish. Therefore the rear pads (and therefore sensors) may have worn through, the wires from the pug coupler in the wheel-arch may look intact but have broken inner cores through work hardening, the plug couplers may be contaminated or the wires crushed.
If it is the red brake symbol, there isn't enough brake fluid in the reservoir - which must be checked out why straight away.
Regarding your flashing car symbol; that is the immobiliser. When the dash has been removed from the car it has upset the immobiliser (the immobiliser is incorporated in the dash). Also, if his machine can't communicate with the immobiliser, this is because the diagnostic K-Line for the ECU goes through the dash (becoming the W-Line) and this is how the immobiliser talks to the ECU. I have a feeling from what you have said that there is a plug coupler on the rear of the dash that has not been connected properly when the dash was re-installed.
Unless the dash was removed and reconnected without disconnecting the vehicle battery (again a very foolish thing to do) all of the immobiliser and key codes should not have been affected.
MY2009 A4 Saloon 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Convenience Key, Sunroof, Adaptive Lights, Anti-dazzle Folding Mirrors, Rear Sun Blind, Heated Full Leather with Memory, Storage/Light Packs, Audi Hold Assist, Adaptive Cruise Control, Parking System Advanced, Privacy Glass, Rear Airbags, TPMS. MMI 2G with B&O Sound System, DAB Radio, DVB TV, AMI and Bluetooth Phone prep High with Privacy Handset.
