Thread: Retrofitted cruise control but not working! Plz Help
  1. Question Retrofitted cruise control but not working! Plz Help
    Sep 2013
    United Kingdom
    I have 2009 A5 3.0 TDI Quattro Automatic, just fitted a Cruise Control Stalk, (The stalk came without the Steering slip ring/coil spring). Used the old coil spring to fit the new cruise control stalk.
    Enabled "Cruise Control installed" Under engine module and steering module. Code is accepted. However cruise control doesn't work at all.
    Getting following error,
    1 Fault Found:
    00895 - Cruise Control Switch (E45)
    014 -- Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 157
    Any help greatly appreciated. Can it be a faulty switch in brake padal at all? Or anything else I need to check?
    Many Thanks
  2. Re: Retrofitted cruise control but not working! Plz Help
    Apr 2013
    Kent
    Do you have the correct steering controller, I'm no expert but I heard some don't have the cruise control function.
  3. Re: Retrofitted cruise control but not working! Plz Help
    Sep 2013
    United Kingdom
    Quote Originally Posted by Avidfanofstuff View Post
    Yes it does have the correct module. Address 16: Steering wheel (J527)
  4. Re: Retrofitted cruise control but not working! Plz Help
    Jan 2012
    Coding Something
    I do wonder if you got the correct stalk assembly, you have to match the pr codes for your old one, wrong one can lead to issues.
  5. Re: Retrofitted cruise control but not working! Plz Help
    Sep 2013
    United Kingdom
    Quote Originally Posted by NHN View Post
    I have used this part for cruise control stalk
    8K0953502BD
    These are the PR codes that i have
    E0A = No specialedition
    7A3 = CD player
    4UF = Drivers andfront passenger air bag with front passenger air bag deactivation
    6XE = Exteriormirrors: electrically foldable and electrically adjustable/heated
    5SJ = Left exteriormirror: convex
    6TS = Right exteriormirror: aspherical, large viewing field
    1KW = Disc brakes,rear
    J0Z = Battery 520 A(110 Ah)
    1LA = Disc brakes,front
    1AT = Electronicstabilization program (ESP)
    1BE = Sportssuspension/shock absorption
    3FA = Without roofinsert (standard roof)
    5MA = Decorativeinserts
    7X4 = Park distancecontrol, front and rear
    F0A = No specialpurpose vehicle, standard equipment
    8GR = Alternator 150A
    0G7 = Tiptronic
    0YG = Weight range 7installation control only, no requirement forecast
    0JH = Weightcategory front axle weight range 8
    T41 = 6-cylinderdiesel engine 3.0 L unit 059.D
    3NZ = Rear seatbench unsplit, backrest split folding
    8BP = Bi-functionalheadlight with gas discharge lamp
    U1B = Instrumentinsert with mph speedometer, clock, tachometer and trip odometer
    X2B = National salesprogram Great Britain
    1N3 = Speed-relatedvariable steering assist (Servotronic)
    1XX = Leathertrimmed multi-function sports steering wheel w/ Tiptronic
    8Q3 = Automaticheadlight-range adjustment dynamic (self-adjusting while driving)
    9Q4 = Multi-functiondisplay/on-board computerwith check control
    8Z5 = Not hotcountry
    D50 = 6-cyl. turbodies. eng. 3.0 l/176 kW 24VV6 TDI, common rail Base engine is T41/TE1/TF1/TH1
    7Q2 = Navigationsystem with color screen
    CE0 = Alloy wheels8.5J x 18
    7K0 = Without tirepressure warning light
    4X3 = Side air bagfront with curtain air bag
    2K1 = Reinforcedbumpers
    3L3 = Manual heightadjustment for front seats
    4KC = Side and rearwindows in heat-insulatingglass
    3Y0 = Withoutroll-up sun screen
    4K2 = Radio remotecontrolled central locking "SZV"
    5D7 = Carrierfrequency 868 MHz without panic button
    1SA = Withoutadditional front underbody guard
    7MB = Emissionstandard EU 4 plus
    Q1D = Sports frontseats
    4GQ = Windshield inheat-insulating glass
  6. Re: Retrofitted cruise control but not working! Plz Help
    Nov 2009
    46 Post(s)
    I fitted cruise to my buddy's 8K A4 this morning, enabled the CC in the engine module and steering module but was greeted with a flashing glow and same error.
    I panicked then remembered I didn't clear the fault (switch fault) as the igntion was on when enabled in engine module but the steering ecu didn't know the stalk was there.
    Maybe something to try?
    It was a 2009 and had Xenons so used the BD switch pack.
    The switch pack that was removed was - 8K0953502BC
  7. Re: Retrofitted cruise control but not working! Plz Help
    Sep 2013
    United Kingdom
    Finally decided to take the Cruise control switches apart. So today I took off the airbag and steering wheel and the stalk. Opened up the all the switches and found that the micro connector switches came out of the lags and not moving with the cruise control lever. Cleaned the circuit board and micro connectors using aftershave to remove carbon deposits, put them back together in correct positions, fitted all back, guess what? Cruise control works straight way... so finally cruise control done for £60 as I bought 2nd hand cruise control stalk and steering lower trim for £60.
  8. Re: Retrofitted cruise control but not working! Plz Help
    Feb 2013
    Gloucester
    57 Post(s)
    good stuff, glad its sorted. (and you probably have the nicest smelling CC stalk going!)
    Audi A7, S-line, 313 PS BiTDI Tiptronic, Daytona Grey, heated front and rear seats, Audi connect, quad zone climate control, ski chute and bag, Rear tints, 75 Litre fuel tank, All LED headlights, Night vision assistant, Rear view camera with corner view, Navigation plus, MMI touch, Heads up display, Adaptive Cruise control, Blind spot monitoring and active lane assist. Audi A5 (wifes) My Kit car blog - http://mitchsgbszero.blogspot.co.uk
  9. Re: Retrofitted cruise control but not working! Plz Help
    Nov 2009
    46 Post(s)
    Good job, cruise fitting is easy on the B8, far easier than my 8P.
  1. Replies: 16
    Last Post: 25-03-2013, 04:39 PM
  2. non working cruise control
    By stevemr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-11-2011, 04:19 PM
  3. Cruise Control Not Working
    By Gabbatek in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 06-07-2011, 09:26 PM
  4. Please Help Cruise Control Not Working?
    By ChrisH1098 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-10-2009, 01:26 PM
  5. A6 Cruise control not working
    By bagpipingandy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-02-2009, 09:42 PM
