Thread: Which climate control will I get?
  1. Which climate control will I get?
    Feb 2013
    Gloucester
    57 Post(s)
    I was just having a browse on auto trader tonight at A7s (as mine should be with me this month) and it seems there are two types of climate control controls in the front of the car. Has there been some sort of facelift or is it dependent on which spec you ordered? There seems to be both sort of unit on both newer on older cars so assume it's the latter but not sure. I prefer the one with two dials and the screen but probably too late to change now. Anyone know?
  2. Re: Which climate control will I get?
    46 Post(s)
    The one with the screens is digital, the other manual. Digital looks nicer.
  3. Re: Which climate control will I get?
    Jul 2012
    Hampshire, UK
    The three dial unit in the lower picture is standard 'automatic air conditioning' whereas the two dial unit in the upper picture is 'deluxe 4 zone automatic climate control'. The exact differences can be viewed in the configurator. Both units are current, the deluxe 4 zone is a £620 option.
    Mine - 2011 A7 3.0 TDi Quattro SE
    Hers - 2013 Mk7 Golf GT 1.4 DSG
  4. Re: Which climate control will I get?
    Feb 2013
    Gloucester
    57 Post(s)
    Brilliant, thanks. Until I found those pictures I didn't even know there was more than one sort of dials. I opted for the 4 zone climate so should be ok and get the unit I preferred the look of.
    Sent from my iPhone using Tapatalk - now Free
  5. Re: Which climate control will I get?
    Aug 2007
    Hook Hampshire
    21 Post(s)
    The benefit of 4 zone climate control is as follows. Better rear seat control for passengers, climate glove box, and this is the real mega thing. When you turn the engine off you can prees abutton for residual heat. This allows the electric water pump in the engine to continue to operate circulating heat from the engine into the cabin keeping the inside warm while you fill up with fuel or pop to the shops. How clever is that! Now for the official information.Climatronic control unit J255 for the four zone air
    conditioning system
    The functions can be activated/deactivated by pushing the buttons.
    The control knob is used for adjusting temperature, blower speed
    and air distribution in the front two climate zones.
    The diode in each button is lit when the function is activated. The
    front climate settings are indicated on the Climatronic control unit
    display and, for several seconds, on the MMI display. The air
    conditioning can be adjusted separately for the driver and front
    passenger sides. In addition, the front passengers can adjust the
    rear cabin settings or synchronise all four zones with the driver's
    climate zone setting.
    Residual heat
    In the four zone air conditioning system the "Residual heat"
    function can be activated when the ignition is "off " by pressing and
    holding the blower speed setting button. The residual heat of the
    cooling water is used for heating the interior of the occupant cell.
    The coolant run-on pump V50 continuously circulates the hot
    water through the heating system. The "Residual heat" function is
    deactivated automatically after approximately 30 minutes.
    Rear air conditioner/Climatronic operating and
    display unit E265
    In the four zone air conditioning system both rear climate zones
    can be controlled by the rear air conditioner/Climatronic operating
    and display unit E265.
    In vehicles with a four zone air conditioning system, a seat heater
    can be ordered as an option for both front seats.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  6. Re: Which climate control will I get?
    Feb 2013
    Gloucester
    57 Post(s)
    Now that it cool! Looking forward to testing it!
    4 days to go
  1. Question climate control blower failure/resistor pack/ control panel ?
    By ianmcneill in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-08-2011, 10:00 PM
  2. Please Help B5 Climate Control
    By wiliferus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-03-2011, 05:53 PM
  3. climate control
    By nunncm in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-11-2010, 11:25 AM
  4. Replies: 2
    Last Post: 08-08-2008, 10:53 PM
  5. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
