Thread: Audi Coupe Quattro running very rough
  1. Angry Audi Coupe Quattro running very rough
    Oct 2013
    A, A
    Hi everyone,
    I recently bought a coupe, and it was working beautifully initially. As its a high mileage and not recently used car, I decided to service it. New Oil, Oil Filter and spark plugs were fitted, and a mis-matched fuel filter almost went on, but was wrong so couldn't be fitted. After this minor service, I have a very annoying problem...
    What I have occurring is that the car starts fine, but after around 5 to 20 seconds, there is a rumble which sounds like a mis-fire and a severe lack of power which progressively gets worse until the car stalls. If the accelerator is pressed anywhere between 1/4 of the way and fully down, the engine seems to increase in rumble-intensity when pressed around 1/4, or stop firing altogether and almost stall when pressed 1/2 way down or more; the inevitable stall can be prevented by releasing the throttle a decent amount if this occurs. Quick bursts of the throttle show an initial delay in engine speed increase, but it does speed up.
    What I have checked:
    I have changed the fuel pump now, as the original old unit was very noisy, and I figured it was causing issue. A direct electrical feed has been used to ensure the supply is not the problem to it.
    A new fuel filter has also been attached, along with new hoses around that area.
    HT Leads have been removed 1 at a time, and each one causes an noticeable misfire when removed.
    Breather Hoses have been checked/replaced
    Electric Multi plugs have had a thorough blast with contact cleaner and corroded spades replaced.
    Old spark plugs been re-fitted
    On a side note, the cold start valve does not send fuel when the engine is cold :S
    Current thoughts to the problem are:
    • The fuel system needs to be bled somehow - anybody know if this is a known issue?
    • The vacuum hoses from the rocker cover are incorrectly fitted or damaged
    • Some demon electrical fault...
    Any suggestions would be GREATLY appreciated. Thanks a lot in advanced!
  2. Re: Audi Coupe Quattro running very rough
    Nov 2008
    Beverley East Yorkshire
    Year engine and model would be very handy for anyone within to help.
    Sounds like fuel starvation, could be injector filters blocked or a vacuuming fuel tank.
    Does it run with fuel cap off?
    Unauthorised commercial link removed as per forum rules
  3. Re: Audi Coupe Quattro running very rough
    Oct 2013
    A, A
    Its a 1988 coupe quattro, with the KV 2226cc n/a engine.
    I will try the fuel tank with no cap tomorrow. However, when I have removed the cap after running the engine there has been no sound of suction of air.
  4. Re: Audi Coupe Quattro running very rough
    Gwent
    Carefully check the ribbed 'igloo' intake hose for splits etc., a vac leak here can cause an increase in airflow WITHOUT a corresponding increase in fuel. Also check the air metering plate is not sticking?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  5. Re: Audi Coupe Quattro running very rough
    Oct 2013
    A, A
    Progress so far: We removed the injectors, and placed each one into a beer bottle of the same size. The pump was then wired up directly to the battery, and then the metering plate was pushed. Only fuel came from number 1 injector constantly, but the others only occasionally jetted - I am right in thinking they should all jet equal amounts all the time while the plate is open? I have now removed the Fuel Distributor to back-flush and clean the system and will test again, along with the pressure.
  6. Re: Audi Coupe Quattro running very rough
    Gwent
    I think there's a possibility the injectors themselves are also 'tired' the 'jetting' you mention should really be more of an 'atomised cone' pattern I think. But yes should be continuous.
    This might help:
    http://www.cis-jetronic.com/public_doc/07.3-0997-06.pdf
  7. Re: Audi Coupe Quattro running very rough
    Oct 2013
    A, A
    Phew! Success at last
    I blew out all the injectors, injector lines and the distributor and cleaned everything as well as inspecting the relief valve.
    When i did the same test after reinstalling everything, each injector squirted out equal amounts and in a nice fan.
    And when i put the injectors back in, the engine purred away like is should.
    Thanks for your help guys. Im sure there will be another question about somthing else soon...
  1. 2002 3.0 quattro running rough
    By xf8u39 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-06-2013, 11:55 PM
  2. 3 litre quattro rough running - Help?
    By tyreos in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-08-2009, 08:26 AM
  3. Please Help Audi A3 1.8T (1998) Misfire/rough running problems
    By Cheekymonkey3 in forum Audi A3 - Archive Topics
    Last Post: 05-09-2008, 01:12 PM
  4. 2001 A8 2.8 Quattro running rough
    By 28a8 in forum A8 - S8 - V8
    Last Post: 01-04-2008, 10:51 PM
  5. audi a3 running rough once warm
    By bobby8595 in forum Archive posts
    Last Post: 20-04-2007, 06:14 PM
