Thread: Optical Bus Quick Question
  1. Optical Bus Quick Question
    Jun 2006
    Hi guys,
    Quick question on the A6 optical bus.
    Do the devices on it need power to maintain the fibre bus functionality?
    Reason for asking is I have errors in my VCDS logs showing intermittent open circuit:
    00384 - Optical Databus
    011 - Open Circuit - Intermittent
    Now originally I was thinking that as my Fiscon bluetooth module was always mentioned alongside this, it was likely this was the cause. I have temporarily disconnected it and all associated wiring to rule it out.
    Now in the past I had issues with battery discharge, and now run the Bose AMP and tuner module in the boot via an ignition switched relay. That means when I turn the engine off the power to those cuts cut straight away, so it could be if you take power off a device it breaks the fibre circuit and is causing this error. Also could mean that if power is needed it could be an electical issue or a problem with fibre wiring or device.
    I will be running the VCDS fibre test later when my car is home to see what that comes up with (should have done this before removing phone module!).
    Recently I've had 2 instances of the MMI just not working, any device like NAV, tuner, DAB, CD etc all show as not installed. Simple, engine off and on and all is well but if something is playing up I'd like to nail it before the winter sets in.
    Thanks guys.
  2. Re: Optical Bus Quick Question
    46 Post(s)
    What time and date are on the error Andy?
    If something was unplugged on the loop the MMI wouldn't even switch on.
  3. Re: Optical Bus Quick Question
    Jun 2006
    Hi Chris,
    That is the thing, you are spot on about if there is a break it won't power on which is making me suspect it could be the mod I put in, and it's to be expected. However I was also getting phone module errors:
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Control Module Part Number: 4F0 910 468 A HW: 4F0 907 468 B
    Component and/or Version: Gateway H09 0030
    Software Coding: EDFE73DC1B3904
    Work Shop Code: WSC 02325 785 00200
    VCID: 2759FFAFEF7D
    2 Faults Found:
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 98
    Mileage: 95702 km
    Time Indication: 0
    Date: 2013.08.27
    Time: 18:44:58
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 138
    Mileage: 95702 km
    Time Indication: 0
    Date: 2013.08.27
    Time: 18:48:35
    Hoping the VCDS test will put my mind at rest, will then reconnect Fiscon and repeat. Can easily take out my relay mod as another variable and leave it all a while to see.
    Never lost of had any MMI issues when car running, only twice it was off when I started up car, and when I tried to put radio on it powers up but says nothing installed, not even the car bit for service indicator etc.
    Keep you posted, hoping something simple.
  4. Re: Optical Bus Quick Question
    46 Post(s)
    I think I mentioned this before but when I had th fiscon in my a3 even tho I followed the coding, it still showed it as not connected and showed errors in the can gateway and telephone module.
    You'll probably get a telephone error when running the optical test tho. Are you running 5570?
  5. Re: Optical Bus Quick Question
    Jun 2006
    Hey Chris,
    You were right, all good bar telephone not found, if it's unplugged and still coded in that could happen !! Quite pleased as thinking it's to be expected. Yes running 5570. Will leave a week or so and see how it goes. Just rechecked fault log on CAN gateway, optical error again listed 2 mins after I saved last logs which is about the time I turned it all off.
    Thanks again.
    Andy
  1. Quick question needs a quick answer please
    By Seboni121 in forum Golf MK6 - 2009 - 2013
    Last Post: 07-03-2012, 06:32 PM
  2. Question CAN-Bus adapter Question
    By mopane04 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-03-2009, 10:23 PM
  3. GOLF V BUS-CAN or BUS R-LADDER ???
    By DSGFAN in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2009, 12:26 AM
  4. quick question quick answer needed please
    By minty0_10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-10-2008, 01:02 AM
  5. Please Help Golf VS Bus...Bus wins
    By LSDJ in forum Golf MK4 - 1999 - 2004
    Last Post: 02-06-2008, 06:32 PM
