Thread: Airbag "PING"
  1. Airbag "PING"
    Feb 2012
    Ipswich, Suffolk
    Bit of an odd one but every now and then I'll have a "ping" sound when starting the car with an airbag light which then goes off about 2 seconds later. No constant lights or fault codes showing? Is it just one of those things? Not too worried because it isn't on all the time but I'm just curious
    mk6 Golf. Graphite Blue. 1.6 TDI. All Factory Standard. Less Than 30,000 Miles.
  2. Re: Airbag "PING"
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    I had that on mine a few months ago and the airbag light would stop on for a couple of seconds more. I did a VCDS scan all clear and it hasn't come back yet.
    There are a few airbag error codes.
    Just wait until it reoccurs then have it scanned.
    VAG Error Code: 00588
    Fault Location:
    Air-Bag Igniter: Drivers Side (N95) - Resistance too Low/Resistance too High/Lower Limit Exceeded/Upper Limit Exceeded/Short Circuit to Positive/Short Circuit to Earth
    Possible Cause:
    Airbag Warning Light active.
    Wiring/Connector(s) from/to Airbag Igniter Driver Side (N95) faulty.
    Coil Spring with Slip Ring (F138) faulty.
    Possible Solutions:
    Check Wiring from/to Airbag Igniter Driver Side (N95).
    Check Coil Spring with Slip Ring (F138).
    Check Airbag Igniter Driver Side (N95).
    Special Notes:
    When "Short to positive" or "Short to earth" is found, DO NOT CLEAR THE DTC. This can cause the airbag to deploy. See repair manual for more information.
    VAG Error Code: 00589
    Fault Location:
    Air-Bag Igniter: Passenger Side (N131) - Resistance too Low/Resistance too High/Lower Limit Exceeded/Upper Limit Exceeded/Short Circuit to Positive/Short Circuit to Earth
    Possible Cause:
    Wiring/Connector(s) from/to Airbag Igniter Passenger Side (N131) faulty.
    Possible Solutions:
    Check Wiring from/to Airbag Igniter Passenger Side (N131).
    Check Airbag Igniter Passenger Side (N131).
    Special Notes:
    As taken from my EOBD II Error Codes
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: Airbag "PING"
    Feb 2012
    Ipswich, Suffolk
    Quote Originally Posted by Keithuk View Post
    There are a few airbag error codes and 2 of them say DO NOT CLEAR THE DTC. This can cause the airbag to deploy.
    What should be done if you can't clear the codes?
  4. Re: Airbag "PING"
    Sep 2009
    12 Post(s)
    It says See repair manual for more information but there is none available apart from ElsaWin so take it to a dealer for investigation.
  5. Re: Airbag "PING"
    May 2008
    London, UK
    Is it the same as this - Audi A1 8X - Zeigertest, Zeigerwischen, Inszenierung aktivieren mit VCDS - YouTube ?
    Just means the passenger airbag is enabled, but I don't understand why some cars do it and others don't
  6. Re: Airbag "PING"
    Feb 2012
    Ipswich, Suffolk
    Quote Originally Posted by J400uk View Post
    Exactly that apart from it only does it occasionally and it doesn't come up in the centre as text. But it is that noise at that time.
  7. Re: Airbag "PING"
    May 2008
    London, UK
    Did you ever find a solution to this OP?
    My Golf has began beeping at startup and I can't work out why. No error lights on the dash and it doesn't seem to be temperature or airbag related like I first suspected. Vehicle status screen in the MFD does not show any problems either.
    edit : turned out to be the tyre pressure warning. Dash light just wasn't coming on for some reason
  1. Please Help "Airbag/B Pretensioner not active"
    By ladycool in forum Golf MK4 - 1999 - 2004
    Last Post: 01-08-2010, 01:43 AM
  2. A "Community" a "Club" or a "Technical Forum"?
    By stuart in forum Chat - Completely Off Topic
    Last Post: 07-03-2009, 02:11 AM
  3. Replies: 0
    Last Post: 06-12-2007, 10:39 PM
  4. A3 "Airbag" Badge - where to buy one?
    By TFT_Warrior in forum Archive posts
    Last Post: 16-10-2007, 09:05 PM
