Thread: Battery for Audi A6 2006
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. Re: Battery for Audi A6 2006
    #21
    Mar 2008
    High Wycombe
    Quote Originally Posted by sapstar View Post
    Also I went to KwikFit to get a quote on battery replacement. They ran some test and said I need both battery and alternator replaced and will cost me £800!!!. I will go to another place and get a second opinion. But do you know if there is any way for me to tell if there is an alternator problem? I don't have any problems with the car which make me feel I need to replace alternator.
    Go somewhere else and get a FIRST opinion, and resolve never to go anywhere near kwik fit ever again.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
    1 1 0
  2. Re: Battery for Audi A6 2006
    #22
    Sep 2012
    Romford, UK
    Hi Guys - just called Battery Megastore and they says that size 020 will not fit in my car as it is 393 mm in length. Their database only shows 315 as the maximum length for Audi A6 2006 Diesel 2.0. Can someone confirm the battery size for my car? Currently I have 017 size in there, but it might not be the right one. Also I cant find 110Ah in 017 size.
  3. Re: Battery for Audi A6 2006
    #23
    Sep 2012
    Romford, UK
    Just checked the battery in my car and see that there is gap for a larger battery to be installed. The currently installed battery is around 350mm. So 4 cm will not be a problem. Finally ordered this one.
    Varta Silver I1 Heavy Duty Car Battery 110AH | eBay
    Thanks for all the help.
  4. Re: Battery for Audi A6 2006
    #24
    Sep 2012
    Romford, UK
    Ordered the battery now. Will follow the instructions from here once I get it.
    Battery Replacement: 2005-2010 Audi A6 - 2008 Audi A6 3.2L V6
    Gupsterg - do I need to buy the plug which you mentioned below? or it comes with the battery? Also the vent tube is currently hanging out in my car. Wasn't sure where it needs to be connected. Will make sure I connect it correctly with the new battery.
    Do connect the vent tube (item 3) and block one side off with cap (item 2) Link:- http://www.jimellisaudiparts.com/sho...String=battery.
  5. Re: Battery for Audi A6 2006
    #25
    Sep 2012
    Romford, UK
    Got the battery and installed it today. Didn't use any backup battery. So lost the time and trip counter. Rest all seems to be working fine. Thanks every one for helping out.
  6. Re: Battery for Audi A6 2006
    #26
    46 Post(s)
    If your esp light is on you can fix it by doing a full lock to lock on the steering and go a short drive and it will clear.
    You'll also have to re-do the one-touch on the windows but that's a 30 second job.
  7. Re: Battery for Audi A6 2006
    #27
    Oct 2005
    Now I can finally say;
    Battery for Audi A6 2006? Seems like a fair swap, you have a deal!
    </coat>
    0 2 0
  8. Re: Battery for Audi A6 2006
    #28
    Sep 2012
    Romford, UK
    Hi Chris - Thanks for the info. I had to deal with ESP light coming on before, when I had to do jump starts. It went off by itself. So not worried that much. I checked all the windows but I have convenience open already enabled even after the battery change, just like before.
    I have noticed one problem though which I didn't have before. When I put my keys in the ignition, I hear a quick cracking sound through the speakers, before the audio start. This wasn't there before the battery swap. Once the audio is running, I don't hear any strange noises.
    I have again checked all the voltages with voltmeter while engine is off and running (with air con, lights, radio on). I see around 1V difference in the readings. According to some information I went through, if there is more than 0.5V increase, then the alternator is working fine. Not sure if this is the right way to check an issue with the Alternator, but for now, I am not going to bother about it. I will get a fault code check when I have a chance.
  9. Re: Battery for Audi A6 2006
    #29
    46 Post(s)
    Yep, just sit back and enjoy the car. Clear all faults and then scan when you have the time.
  1. Please Help Audi A3 2006 TDI 2.0 Battery drain
    By kma01 in forum Chat - Anything with wheels
    Last Post: 23-01-2013, 01:32 PM
  2. Replies: 6
    Last Post: 20-02-2012, 08:34 PM
  3. A6 2006 BAttery Coding
    By snight123 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-04-2011, 10:10 AM
  4. 2006 A6 Battery issues
    By wmccann in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-04-2009, 04:08 PM
  5. Polo (2006 model) battery removal
    By barnacle in forum Chat - Anything with wheels
    Last Post: 02-11-2008, 01:04 AM
