Thread: Replacing alarm horn (H12), but unable to locate
Results 1 to 8 of 8
  1. Replacing alarm horn (H12), but unable to locate
    Jun 2011
    Worcester
    Hi, sorry to ask but I'm trying to clear all the faults on the car. One of them is the failure of the H12 alarm horn.
    Now I've looked at the workshop manuals, which shows its located in the pelnum chamber - but I canot locate it.
    I've asked the dealer who said, yess in the pelnum chamber.
    Anyone swapped this out?
    I'll post the pick from the manual (later), which has me confused.
    Thanks - rob
  2. Question Re: Replacing alarm horn (H12), but unable to locate
    Jun 2011
    Worcester
    Quote Originally Posted by Dpanic View Post
    Thanks - rob
    OK - from my manual all I can find is this, remove nut 2 and 3 - then take out brack 1 - underneath is the horn.
    But I have no brack, nothing is there.
  3. Re: Replacing alarm horn (H12), but unable to locate
    46 Post(s)
    The manual sometimes can demonstrate LHD cars - post #7 here - Please Help, water in footwells! - AudiWorld Forums
  4. Re: Replacing alarm horn (H12), but unable to locate
    Jun 2011
    Worcester
    yeh, looking at the Vid on the link the final view (after it comes back into focus) is what I see. you have the two valves for the heater, then it should be on the right / or the left (differrent countries) - but I see nothing. I've been looking all over the chamber and nothing, AUDI say its there... but when I asked exactly ... they did not respond (waiting for it to be booked in I bet). If its somewhere else - the only possible place (might be wrong) - is the casing next to the front suspension (wheel arch)- the odd one with the security screws (I'll get a pick of this to show - as cables disapear in side. ... as its only the battery back up unit ... do others with the same issue just leave it?....
  5. Re: Replacing alarm horn (H12), but unable to locate
    Nov 2012
    Somerset UK
    Ooops read this as car horn instead of alarm horn.
    So your alarm doesn't chirp when you lock it?
  6. Re: Replacing alarm horn (H12), but unable to locate
    You do not say what year or mdel. But the saloon alarm is behind the LHS boot trim behind the tools and on the Avanyt it is behind the trim on the RHS. Regards Peter
  7. Re: Replacing alarm horn (H12), but unable to locate
    Jun 2011
    Worcester
    Quote Originally Posted by Peter D View Post
    my applogies, its a 2005 avant , (3.0 quattro). I've had the boot trim off in the last - not noticed it... I'll remove both and re-check.
    Thanks for the reply.
  8. Re: Replacing alarm horn (H12), but unable to locate
    You have to remove the amplifier and base speaker, then the insulation and it reveals the Alarm system horn. Regards Peter
  1. Alarm Horn (H12)
    By Starstreak in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-03-2011, 10:03 PM
  2. 01134 - Alarm Horn (H12) Fault Help please
    By midge6 in forum VCDS - Help Requests
    Last Post: 16-12-2008, 03:52 PM
  3. Replace H12 Alarm Unit Backup Battery
    By richard@thebrae in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-06-2008, 10:35 AM
  4. Alarm Horn ????
    By tennentsfan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-02-2008, 06:44 PM
  5. Golf Alarm Horn
    By Bushy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-04-2007, 11:41 PM
