Thread: How do I separate and reassemble Polo Mk4 (9N1) driveshaft and hub?
  1. How do I separate and reassemble Polo Mk4 (9N1) driveshaft and hub?
    Mar 2007
    Hi, I need to replace the shock absorbers on my Polo. Following the Haynes manual, I removed the driveshaft nut, anti-roll bar link, undid the lower arm ball joint and steering track rod ball joint. The driveshaft is very tight in the hub. Tried hitting it using a metal rod against it but no luck - didn't want to damage the shaft end. I am thinking of buying a puller (Clarke CHT240). Will I then have problems putting the shaft back in the hub and have to buy a driveshaft puller? They (Laser 4847) seem to cost £150 and DIY soon becomes uneconomical as my local garage has estimated £130 per side. Any advice will be gratefully received.
  2. Re: How do I separate and reassemble Polo Mk4 (9N1) driveshaft and hub?
    Nov 2010
    bishops stortford, UK
    it can be done much more easily that this.
    Basically undo the 3 13mm nuts on the lower suspension arm, and then the 36mm hub nut in the centre of the wheel. This will allow the whole suspension leg to pivot outwards.
    You then need to undo the lower shock fixing bolt think 16mm nut and then a hex key for the bolt itself.
    Lastly undo the 3 13mm bolts holding the top of the shock to the tower and it should all come out in 1 piece.
    Hope this helps
  1. Polo 9N1 ABS problem - what will I find?
    By the_old_diver in forum Polo - Derby - Lupo - Fox
    Last Post: 06-12-2012, 09:12 PM
  2. Question Polo 9n1 cold engine power loss
    By amftdi02 in forum Polo - Derby - Lupo - Fox
    Last Post: 12-07-2012, 09:05 AM
  3. Polo 1.2 2003 9N1 Coil Spring
    By avotech in forum Polo - Derby - Lupo - Fox
    Last Post: 30-05-2011, 07:14 PM
  4. Question MK4 GT TDi Hub Diameter
    By Jockeyblade in forum Golf MK4 - 1999 - 2004
    Last Post: 08-03-2010, 12:11 PM
  5. Wheel hub the same for mk4 golf 4 motion as it is for mk4 1.9 tdi???
    By imortalmonkey in forum Golf MK4 - 1999 - 2004
    Last Post: 14-05-2009, 07:53 AM
