Thread: Glow plug replacement
  1. Glow plug replacement
    Dec 2011
    Bishops Stortford
    I need to replace a glow plug but my question is whether I should replace 1 or all of them.
    Advise is much appreciated
  2. Re: Glow plug replacement
    Norfolk
    That's up to you but use NGK plugs or Genuine VW only.
  3. Re: Glow plug replacement
    DSG4ME Guest
    Quote Originally Posted by martin1810 View Post
    7v ones only, so no buying 4.4v ones cos they are cheaper
    @ op, you know these are inside the head and do snap if you ain't careful when trying to remove them don't you, just prepping you so you don't get tripped up later.
  4. Re: Glow plug replacement
    Dec 2011
    Bishops Stortford
    Only going to buy the ngk items. Are there any special tools needed. Dont suppose you know of any guides available.
  5. Re: Glow plug replacement
    DSG4ME Guest
    Quote Originally Posted by willc1985 View Post
    Wise move,
    Sadly I couldn't find a how 2 when I had one out, the nearest I found was an A4 engine iirc and afaik they aren't the same, I believe they sit next to the injectors but there's no need to remove anything other than the loom feeds from the top of the glowplugs.
    Another thing I read was if they feel tight hit them with some penetration oil product and wind in and out gently bit at a time until it's moving freely, remember to change you oil afterwards if you do use a lube on them.
  6. Re: Glow plug replacement
    Dec 2006
    Stoke/Congleton
    I think it's a 8mm deep socket but it could be 8 to 10mm as I can't remember. You can recognise them as they have 1 green wire (I am slightly colour blind) and a tall black plastic cap, this pulls off with long nose pliers. 10nm torque.
  7. Re: Glow plug replacement
    Dec 2006
    Stoke/Congleton
    No dropping allowed butter fingers, as they are supposed to be delicate.
    By crazy4alfa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-09-2013, 08:17 AM
  2. Question Glow Plug Replacement
    By Dazzler01 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-10-2012, 09:26 AM
  3. glow plug replacement
    By bagseye in forum Early Passat Forum - Pre 97
    Last Post: 22-03-2009, 10:13 PM
  4. A6 2.5 TDI Glow Plug Replacement.
    By jahgti1 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-01-2009, 07:56 PM
  5. glow plug replacement
    By nicfw in forum Chat - Anything with wheels
    Last Post: 08-04-2007, 07:19 PM
