Thread: Fault code help
Results 11 to 20 of 22
  1. Re: Fault code help
    Mar 2009
    Poole
    Help me please!!!!
    I have an Audi A4 2.0 TDI B8 Chassis
    I have the following faults and the engine running rough on idle, the engine light keeps coming on, and the coil light seems to flicker every 60ish seconds. I have reset the codes several times over the past couple of weeks, but they keep coming back. I have VCDS, but very limited knowledge on how to use it.
    6 Faults Found:
    5293 - Throttle Valve Actuator Module (J338): Motor Circuit
    P2103 00 [044] - Signal High
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 254
    Mileage: 129167 km
    Date: 2014.03.02
    Time: 11:42:05
    5294 - Throttle Valve Actuator Module (J338): Motor Circuit
    P2103 00 [036] - Signal High
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Mileage: 129204 km
    Date: 2014.03.03
    Time: 16:32:14
    5295 - Throttle Valve Actuator Module (J338): Motor Circuit
    P2102 00 [044] - Signal Low
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 34
    Mileage: 129187 km
    Date: 2014.03.02
    Time: 15:44:26
    5296 - Throttle Valve Actuator Module (J338): Motor Circuit
    Freeze Frame:
    Fault Priority: 2
    Mileage: 129185 km
    Date: 2014.03.02
    Time: 15:41:12
    4984 - Cylinder 1 Glow Plug Circuit (Q10)
    P0671 00 [096] - Electrical Fault
    9124 - Throttle Actuator Control System
    P2111 00 [096] - Stuck Open
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 129062 km
    Date: 2014.02.27
    Time: 18:25:15
    Readiness: 0 3 0 0 0
    Where would I find EGR, Throttle Valve, DPF?
    Thank you in advance for any help.
    Regards
    Ben
  2. Re: Fault code help
    Dec 2010
    Wiltshire
    Replace throttle valve and glow plugs (i'd advice all 4, £45 from ECP). Valve is on the right hand side of the engine where intake pipe comes in.
    If you are struggling to find them, I'd advice you to get specialist to have look.
    If you keep driving it with these faults, you will clog your DPF and replacement is £750+.
  3. Re: Fault code help
    Mar 2009
    Poole
    Good evening, thanks for your quick reply. Who are ECP?
    I'm fairly confident at taking things apart and putting them back together, plus I can't afford to take it to a garage at the moment.
    How much is throttle valve?
    Are the glowplugs £45 for the set?
    Will I need to clean EGR?
    Will I need to do a forced regen?
    How do I identify the parts I will need?
    Is there a way of testing the soot using VCDS?
    Sorry for all the questions, but all and any help is much appreciated :-)
  4. Re: Fault code help
    Mar 2009
    Poole
    Sorry just clicked that ecp are euro car parts!!!!
  5. Re: Fault code help
    Dec 2010
    Wiltshire
    Do you have DPF light on? IF not, don't worry about regen, just take it for a drive.
    You can test soot via VCDS via Advanced measuring blocks, i think it around number 100.
    Throttle valve is around £170 and set of glow plugs £45 (Beru ones are same genuine).
    ECP is eurocarparts. Beru for glow plugs and throttle valve is Siemens.
  6. Re: Fault code help
    Mar 2009
    Poole
    No DPF light on, just engine and coil.
    Is the trottle valve a common problem?
    I can't seem to find the throttle valve on ecp.
    Will I need any specialist tools?
  7. Re: Fault code help
    #17
    Dec 2010
    Wiltshire
    No specialist tools.
    Throttle valve is very common to fail.
    Pm me your reg and I will send you a link.
  8. Re: Fault code help
    #18
    Mar 2009
    Poole
    Heres my readings, I ticked a few other possible related items!!!!
    Address 01: Engine (03L 906 022 JM)
    21:43:17
    078 Particle filter; soot mass calculated 21.87 g
    079 Particle filter; soot mass measured 21.70 g
    119 Throttle valve position (absolute) 87.8 %
    142 EGR valve feedback 78.89 %
  9. Re: Fault code help
    #19
    Mar 2009
    Poole
    Thanks for PM'ing part number.
    How long do you think it would take to replace glow plugs and throttle valve?
    Could I clean EGR with carburetta cleaner?
    Oh and am I likely to loose any fluids?
    Do you know what gaskets i would need to replace if i took out the EGR valve and cleaned it?
    I am hoping to sort my car out tomorrow, weather depending.
  10. Re: Fault code help
    #20
    Mar 2009
    Poole
    Last night I replaced my throttle body and glow plugs - Thanks for your help crazy4alfa :-)
    All seems ok, and no fault codes ........ yet!!!
    When i removed the old throttle body, oil came out of the electrical connection, and there was oil in the body and intake pipe. Is this normal?
    I had a full service carried out before i did the repairs if this has any relevance.
    Thanks in advanced for any help :-)
  1. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  2. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  3. VAGCOM Fault Code 00588 - Airbag fault
    By headache56 in forum VCDS - General Questions
    Last Post: 31-01-2009, 01:05 PM
  4. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
