Thread: Rear passenger door won't open
Results 1 to 9 of 9
  1. Rear passenger door won't open
    Aug 2013
    West Yorkshire
    Hi Guys,
    My rear passenger door has stopped opening from the outside. I can open the door from the inside but not from the outside. Having scanned through some previous posts I applied the fix of holding the interior handle in the open position and then pulling on the exterior handle. This then allows the door to open from the outside.
    If I lock the car then unlock the doors via the key the door does not open from the outside.
    Any ideas what it could be ?
    thanks
  2. Re: Rear passenger door won't open
    46 Post(s)
    Have you been fiddling in the MMI settings for Central Locking?
    I'd be getting a fault code scan done.
  3. Re: Rear passenger door won't open
    Aug 2013
    West Yorkshire
    Hi Chris,
    Thanks for the reply. I haven't been messing with the mmi. Prob will need a fault scan just wondered if anyone had any suggestions.
  4. Re: Rear passenger door won't open
    46 Post(s)
    A fault scan should pinpoint the problem, have a look here - VWAF User Location Map - VCDS - Google Maps and if theres anyone near let me know, and I will bring their attention to this thread to contact you as you're halfway to having 10 posts for PM.
  5. Re: Rear passenger door won't open
    Aug 2013
    West Yorkshire
    Thanks - couple of folks in halifax. I'd be grateful if you could make them aware of my thread.
    sjoliff, RickT
  6. Re: Rear passenger door won't open
    Dec 2010
    Milton Keynes UK
    I have a Passat with a similar problem. One of the rear doors is firmly locked but before it gave up the symptoms were pretty much as you describe. I've been told it's a knackered solenoid and about £200 to put right, if you get it done before it properly gives up the ghost like mine has done. After it's given up the ghost, as mine has done, you need to get into the door to unlock it before it can be sorted and the final bill could end up being rather more. My other rear door is starting to show the same signs so will be getting it looked at sharpish! Different car I know but hopefully that helps a little.
  7. Re: Rear passenger door won't open
    Jan 2013
    Scotland
    11 Post(s)
    this happened to me, though i had child locks on so it made it difficuilt to do...i had to put the window down and try it, luckily it worked, never happened again.
    Audi A6 3.0 BiTDI Black Edition
  8. Re: Rear passenger door won't open
    This happened to my last B8 and the door could not be opened at all. Door trim had to be cut from the inside to get at the mechanism to open the door. Luckly the car was under warranty. The whole door trim had to be replaced once the problem was fixed. Could be expensive i guess if that is needed.
    ___________
    New Car- 2012 B8 A4 Avant 2.0 TDIe SE, Moonlight Blue, Privacy glass, Sports Steering Wheel
    Old Car - 2008 B8 A4 saloon 2.0 TDI SE, Aruba Blue, Rear Parking Sensors, Phone Prep
  9. Re: Rear passenger door won't open
    Aug 2013
    West Yorkshire
    Thanks for your comments guys. The culprit was a dodgy door lock catch. Part number (8k0839015) and cost £93 from audi.
    Got to it fitted by a mate.
  1. Please Help Passenger rear door wont open from inside?
    By BigPhysco in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-05-2013, 09:17 PM
  2. a3 8p rear passenger door won't open from outside
    By audijay73 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-10-2012, 03:14 PM
  3. Replies: 0
    Last Post: 07-02-2012, 12:25 PM
  4. passenger door want open
    By hairypothead87 in forum Vento - 1994 - 1998
    Last Post: 07-06-2011, 08:26 AM
  5. Replies: 5
    Last Post: 28-04-2008, 10:34 PM
