Thread: Passat VVT device on inlet cam??
Results 1 to 10 of 11
  1. Passat VVT device on inlet cam??
    I have a 52 plate Passat 2.0 ALT engine code(5 valve per cylinder). It is a twin cam engine with the cams linked by a chain. There is a device fitted on the end of the inlet camshaft that looks like a variable valve timing assembly.
    How on earth does it disconnect from the camshaft? My Esawin is not working on my pc and im desperate to get the car back on the road. Any advice greatly appreciated.
  2. Re: Passat VVT device on inlet cam??
    2019 Post(s)
    It is just very tight, 80Nm + 90 degrees which is around 100Nm. You MUST use a new bolt, part number N 105 216 01 which is £2.94. If you re-use the old one it is highly likely to fail and destroy your engine.
  3. Re: Passat VVT device on inlet cam??
    Thanks for the reply but there is no visible bolt etc that connects it to the camshaft. How is it connected? The part that i am referring to is on the bulkhead end of the camshaft. The part number is 06B109088C if that helps.
  4. Re: Passat VVT device on inlet cam??
    Anybody???
  5. Re: Passat VVT device on inlet cam??
    2019 Post(s)
    There is a Torx head bolt in the centre, T45 if I remember well. 06B 109 088 C is now 06B 109 088 D and costs £391.22 if you damage it. The bolt in the centre is VW part number N 105 216 01.
    1 Cap. Pierce using a screwdriver and prise out. Press new cap in flush
    2 100 Nm
    3 Camshaft adjuster
    4 Drive chain. Before removing, mark direction of rotation (installation position) if re-using
    5 10 Nm
    6 Chain tensioner. Only rotate engine when chain tensioner is installed
    7 8 Nm
    8 Connection
    9 O-ring
    10 Valve timing housing
    11 With camshaft adjustment valve 1 -N205-.
    12 Valves Do not rework, lapping-in is permitted. Exhaust valves sodium filled
    13 8 Nm
    14 Seal For inlet camshaft
    15 Screen For Hall sender When installing note fixing arrangement
    16 Washer. Conical. Note installation position.
    17 25 Nm
    18 Hall sender -G40-
    19 65 Nm Use counter hold tool -3036- to loosen and tighten
    20 Camshaft pulley. Narrow web of camshaft toothed belt pulley faces outwards and TDC No. 1 cylinder marking is visible
    21 Seal for exhaust camshaft
    22 Cylinder head
    23 Valve guide
    24 Valve stem seal
    25 Valve spring
    26 Valve spring plate
    27 Cotters
    28 Bucket tappet
    29 Inlet camshaft
    30 Exhaust camshaft
    31 Retaining frame With integrated camshaft bearings. Coat sealing surfaces with sealant -D 154 103 A1-.
    The reworking dimension “a” is measured through the cylinder head bolt holes. -a- = at least 139.2 mm
  6. Re: Passat VVT device on inlet cam??
    Whoa, you certainly come up with the goods. I will take a close look for the cap in the morning. Thanks so much.
  7. Re: Passat VVT device on inlet cam??
    Had a look this morning and there is no cap??? In the diagram I can see that No2 passes through the gear(No3) on the end of the cam and bolts that on. How is No10 connected to the camshaft? There are 3 bolts (No 5) that hold the housing on but if I undo them
    the housing (No 10) will not pull out of the camshaft.
    There must be some sort of snap ring or something but I cant see it and as you said, its an expensive piece if I break it.
    Hate to say that I am a qualified mechanic but just cant see how this fits into the cam unless its stuck in it!!
    Thanks for your time in answering my problem.
  8. Re: Passat VVT device on inlet cam??
    2019 Post(s)
    The N205 control valve item 10 bolts to the head and just comes off after removing the three bolts.
  9. Re: Passat VVT device on inlet cam??
    Thanks for your help. Don't know whats going on with this one as it will not come off. I will put it back together and hope that all is well.
  10. Re: Passat VVT device on inlet cam??
    May 2017
    France - Annecy
    Hello gkm,have you find a solution ?
    I have an Audi A4 2.0 20v ALT engine, but after have unscrew the 3 bolts, it's impossible to unplug the n205 valve...
    thank you
  1. Inlet cam 2.0 tdi...which one?
    By sparkymarky in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-09-2021, 07:48 PM
  2. Question Polo 6n2 gti VVT
    By Davieboy in forum Polo - Derby - Lupo - Fox
    Last Post: 25-09-2010, 02:06 PM
  3. What is that device in my passat?
    By gurisingh in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2009, 08:30 AM
  4. Passat 1.8 20V cam chain
    By Petenharvsdad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-04-2009, 09:37 PM
  5. passat 1.9tdi, oil in air inlet
    By southamptonadi in forum Archive posts
    Last Post: 17-11-2007, 05:13 PM
