Thread: Retro fit genuine Bluetooth 2g MMI High 2008 S-Line
  1. Retro fit genuine Bluetooth 2g MMI High 2008 S-Line
    Feb 2010
    bluntisham cambs
    Morning all,
    looking at retro fitting the genuine Bluetooth to my A6, few questions as usual.
    First off, bt module? Various around, with different numbers at the end, any reason?
    fitting kit, does any one know of just the loom/mic kit?, seem to be much cheaper separately.
    And coding, are the units code locked to chassis? If so, can the code be cleared/re-set with VCDS
    Install guide/wiring diagram, anyone seen such a thing?
    the collectives thoughts would, again, be much appreciated.
  2. Re: Retro fit genuine Bluetooth 2g MMI High 2008 S-Line
    Apr 2013
    Kent
    Chris did a guide to fitting bluetooth into his A3 with pics.... Might give you an idea...
    VW AUDI Forum - VWAF
  3. Re: Retro fit genuine Bluetooth 2g MMI High 2008 S-Line
    Feb 2010
    bluntisham cambs
    Hi there, thanks for that,
    have seen Chris's guide but that's on an A3 with RNS, the fitting kit is totally different for the 2g MMI.
    Im ok with the hardware install, mic-controller-loom run, it's the connections I'm really after plus a supplier for the loom, not sure if Audi do just the loom, if so I doubt it'll be cheap ish.
  4. Re: Retro fit genuine Bluetooth 2g MMI High 2008 S-Line
    46 Post(s)
    My guide will show you how to route the mic to the light, you just need a different BT module and loom.
    There are usually kits available on ebay but there only seem to be modules atm - AUDI MMI 2G A4 A5 A6 A8 Q7 BLUETOOTH BTA Rsap 4E1862335 SW 4F1910336B | eBay
    Keep searching for 'mmi 2g Bluetooth' and you should see a kit appear pretty regularly.
    You'll need someone with vcds to enable it however.l
    Edit - keep an eye in this seller - http://www.ebay.co.uk/sch/m.html?_fr...empoland&rt=nc as he's he one who sells the kit as a whole including wiring and microphone he has none up at the minute but maybe worth a message to him?
  1. which DAB to fit? A6 S-Line C6 2008 Avant MMI 2G High With Nav
    By diesel.5 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-08-2013, 08:39 AM
  2. MMI 2G High Bluetooth
    By shavermcspud in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-11-2012, 11:42 AM
  3. Replies: 25
    Last Post: 27-09-2012, 06:34 AM
  4. Do I have Bluetooth on MMI High?
    By Mogster52 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-01-2012, 05:12 PM
  5. Bluetooth Retro fit
    By PhilMill63 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-03-2011, 07:26 PM
