Thread: 2007 S6 (c6) with esp/epc/many fault codes/safe mode ARGH
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
  1. Question questions
    phlexmedia Guest
  2. Re: 2007 S6 (c6) with esp/epc/many fault codes/safe mode ARGH
    Nov 2009
    46 Post(s)
    Welcome to VWAF.
    Scan with VCDS and post up, is it a HEX USB CAN version?
    I'll look online and get the descriptions of your codes provided however.
    I can't stress enough on how important it is to get a proper diagnostic!
    18436/P2004/008196 - Ross-Tech Wiki
    16684/P0300/000768 - Ross-Tech Wiki
    16558/P0174 - Ross-Tech Wiki
    16559/P0175 - Ross-Tech Wiki
    16555/P0171/000369 - Ross-Tech Wiki
    16452/P0068/000104 - Ross-Tech Wiki
  3. Re: 2007 S6 (c6) with esp/epc/many fault codes/safe mode ARGH
    phlexmedia Guest
  4. Re: 2007 S6 (c6) with esp/epc/many fault codes/safe mode ARGH
    Nov 2009
    46 Post(s)
    Okay when you first plug it in, go into the Applications menu, press Erase All DTCs, let it do its thing then switch the ignition off and on a few times then rescan just to rid any old or false ones.
  5. Re: 2007 S6 (c6) with esp/epc/many fault codes/safe mode ARGH
    phlexmedia Guest
  6. Re: 2007 S6 (c6) with esp/epc/many fault codes/safe mode ARGH
    Oct 2005
    As Chris says, run the scan, make a note of the codes, clear them and then scan again in a few days time.
    Any codes that return are the ones you need to be investigating, forget the old codes
  7. Re: 2007 S6 (c6) with esp/epc/many fault codes/safe mode ARGH
    phlexmedia Guest
  8. Re: 2007 S6 (c6) with esp/epc/many fault codes/safe mode ARGH
    Nov 2009
    46 Post(s)
    Thats a bit better -
    18055/P1647/005703 - Ross-Tech Wiki
    18061/P1653/005715 - Ross-Tech Wiki
    18331/P1923/006435 - Ross-Tech Wiki
    01826 - Ross-Tech Wiki
    00003 - Ross-Tech Wiki
    ^^ all your engine related errors, read all the links.
    CAN Gateway errors - you see everything in the scan which says Cannot Be Reached? Go into the CAN gateway and untick those modules as it looks like you or someone has been fiddling and made a balls up lol
    Battery errors, looks like you need a new one and should clear all the Voltage related errors.
    03006 - Ross-Tech Wiki Backup camera, go into the park module, go into basic settings or adaption and calibrate it.
    Towbar - 01517 - Ross-Tech Wiki does the car have a towbar or did have one?
    Cut your scan down a wee bit to make it a bit easier to read
  9. Re: 2007 S6 (c6) with esp/epc/many fault codes/safe mode ARGH
    phlexmedia Guest
  10. Re: 2007 S6 (c6) with esp/epc/many fault codes/safe mode ARGH
    Nov 2009
    46 Post(s)
    When were the coilpacks changed? Ie what date and what date did they look at it again?
  1. mk5 golf r32 EPC EML ESP lights on and limp mode
    By volkswizard in forum VCDS - General Questions
    Last Post: 10-10-2013, 07:59 AM
  2. ESP EPC then Emissions lights. Car in limp mode
    By wobblish in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-05-2012, 02:38 PM
  3. ESP / EPC fault codes advice.
    By mickk in forum VCDS - General Questions
    Last Post: 15-02-2010, 11:10 AM
  4. Help 2007 GTI Stereo safe mode
    By mikeypeo in forum Golf MK5 - 2004 - 2009
    Last Post: 09-01-2008, 10:10 PM
  5. Vw Sharan Auto Gearbox Fault,running In Safe Mode ?
    By mck.motors in forum Archive posts
    Last Post: 10-10-2007, 10:54 PM
