Thread: STOP. Low oil pressure
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
  1. Question STOP. Low oil pressure
    Sep 2013
    Weston-s-Mare, UK
    Hi everyone. Newbie here. I'm desperately seeking advice regarding the LOW OIL PRESSURE Warning.
    The warning came up yesterday after picking the car up from our friends house following a night out. As soon as I started to accelerate the warning came up so I gingerly drove it the half mile home.
    After trawling through the internet for suggestions on the possible problem, I decided that as it was close to the next service point, I would check the oil pick-up pipe for blockage and fit a new oil filter and refill with the recommended premium oil. There was no sludging in the sump or any deposits blocking the pick-up pipe.
    Oil was even coming through the mesh onto a rag while I was wiping it over. After just finishing this, the problem remains. I have disconnected and reconnected the pressure sensor on the oil filter body and this also has made no difference.
    Question: Should the oil pressure sensor connection wobble around a bit as it feels like it doesn't seem to locate centrally in the connector? Desperate for help as I use this for my Taxiing job and being off the road means no earnings...
  2. Re: STOP. Low oil pressure
    46 Post(s)
    Welcome to VWAF.
    Which engine? Engine code too if possible, data sticker in your spare wheel well will tell you it.
    Any oil pressure warning you should stop straight away!!
  3. Re: STOP. Low oil pressure
    Colchester,Essex
    If it is a 2.0tdi than I`m afraid a new oil pump job that is.Not a cheap job.
  4. Re: STOP. Low oil pressure
    Sep 2013
    Weston-s-Mare, UK
    Hi A6_Chris. I'll go get the info now...
  5. Re: STOP. Low oil pressure
    Sep 2013
    Weston-s-Mare, UK
    Hi Chris. Back again. Does BKP sound right?
  6. Re: STOP. Low oil pressure
    Sep 2013
    Weston-s-Mare, UK
    Its a 2.0 TDI 140
  7. Re: STOP. Low oil pressure
    Mar 2011
    Clitheroe, England
    11 Post(s)
    Do a search for Oil pump, or hex shaft. As Turpal has said, these 2.0 140 engines can be prone to oil pump failure which would result in the oil pressure low message. I highly recommend not even trying to turn it over, let alone driving it. Get it recovered to your mechanic of choice & pray that driving that half mile hasn't done too much damage, as your oil won't have been getting through to where it would normally be pumped through to & you won't have had lubrication in some vital engine parts.
    It could be something else, but until you get it checked out, it's not worth the risk.
    Good luck, I hope it's not too serious.
    The Only Way Is A6!
  8. Re: STOP. Low oil pressure
    Sep 2013
    Weston-s-Mare, UK
    Could it be a faulty sensor? It felt lke the connection was loose...!!!
  9. Re: STOP. Low oil pressure
    46 Post(s)
    Get a fault code scan done and hopefully something will come up.
  10. Re: STOP. Low oil pressure
    Sep 2013
    Weston-s-Mare, UK
    I have an RAC Code Reader that has thrown up 2 glow plug faults but they have been like that for some time. No oil pressure faults though which made me think it might be the sensor. Have heard of a Recall Campaign 13D8. Is it worth me going down that route?
  1. Oil Pressure Stop Help please
    By parkerm35 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-02-2013, 03:14 AM
  2. STOP oil pressure warning - oil pump failure! Help please
    By jamer78 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2012, 03:54 PM
  3. Stop!!! Low Oil Pressure!!!!!
    By bubblesaint in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-03-2011, 04:43 PM
  4. Low oil Pressure - STOP! Loss of power
    By kunaalv in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-07-2010, 06:32 PM
  5. STOP ! Low Oil Pressure Warning
    By Tnarg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-01-2008, 11:33 AM
