Thread: Mk2 Touran fog light retro fit?
  1. Mk2 Touran fog light retro fit?
    Jan 2010
    Has anyone retro fitted fog lights to a Mk2 Touran, specifically SE (UK spec)
    Dealer has quoted over £500 in just parts, including a new convenience unit, but no mention of wiring.
  2. Re: Mk2 Touran fog light retro fit?
    Dec 2009
    hererfordshire
    Hi, Im trying to do the same thing, have you managed to do it. Ive purchased lamp units and grills for ebay for £55, just got to purchase the light switch now for £25. Would you know if the wiring is already in place. would it be a case of plug and play etc. Cheers
  3. Re: Mk2 Touran fog light retro fit?
    Dec 2013
    London
    Anyone done this yet?
  4. Re: Mk2 Touran fog light retro fit?
    46 Post(s)
    You need Elsa to check the pin outs on the central electric module under the steering wheel, wires, new light switch and the fog lamps themselves.
  5. Re: Mk2 Touran fog light retro fit?
    Jan 2010
    I was told a new bcm module and harness at £400
  6. Re: Mk2 Touran fog light retro fit?
    46 Post(s)
    You need an autoscan from vcds so we can see the version of your CCM whether it's compatible or not.
  7. Re: Mk2 Touran fog light retro fit?
    Jan 2010
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 084 H HW: 5K0 937 084 H
    Component: BCM PQ35 B 021 0068
    Revision: BA021001
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 S HW: 7N0 907 530 J
    Component: J533 Gateway H43 1632
    Revision: H43
  1. touran retro fitting front fog lights
    By hardtail in forum Touran - Sharan - Caravelle
    Last Post: 15-07-2015, 11:45 AM
  2. Fog Lights retro fit A3 TDI
    By mangelwurzel in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-01-2010, 08:58 PM
  3. Fog Light Retro Fit?
    By podwin in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-07-2009, 10:27 AM
  4. Sat Nav Retro Fit Fog Light Switch Problem!!!!
    By Kevin Hay in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-03-2009, 08:15 PM
  5. Is it possible to retro fit fog lights??
    By Aaftab in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-10-2008, 04:45 PM
