Thread: Climatronic Display
Results 1 to 10 of 10
  1. Climatronic Display
    Aug 2006
    When I switch ignition on, on my 1998 1.9tdi passat, tha climatronic display flashes for approx 10secs. The owners hand book says "contact a VW dealer", why? is this a problem that can't be resolved with DIY or do VW dealers really need the funds?
  2. Re: Climatronic Display
    7 Post(s)
    The flashing display indicates that there is a fault with the system.
    You have two options;
    1, Search online for info on how to interogate the clima unit itself to retrieve the fault stored in it.
    or
    2, Get it read for faults by someone off here with vagcom (look in the vagcom sub forum) and/ or a local garage and / or VW themselves as the book says.
    My guess would be the fault is going to be a faulty V71 air flap control motor, very very common.
  3. Re: Climatronic Display
    Aug 2006
    Thanks Col, will follow your leads
  4. Re: Climatronic Display
    Aug 2006
    Bog Col,,,,,,,, would a V71 airflap control motor stop my car firing???
    after oil change last week my cars never moved, the engine turns but does not fire, I looked at the oil level today and the max level is exceeded by about 10 - 12 mm, could this stop the engine firing????
    clutching at straws but any help appreciated
  5. Re: Climatronic Display
    7 Post(s)
    No, it should be fine. Whilst not ideal, to high an oil level shouldn't stop it running.
  6. Re: Climatronic Display
    Aug 2006
    Climatronic display update..More info, The heater motor is not running, discovered fuse had blown. Changed fuse and fan motor ran for about 10 seconds berfore stopping, changed fuse again fan ran for about 10 seconds before again stopping.
    Any ideas for bits to check, could it be motor brushes? is there a temp cut off?
  7. Re: Climatronic Display
    Aug 2006
    Update on Heater Fan Motor
    Motor replaced with new unit today, fan ran for short while & seemed OK, switched everything off and refitted glove box, started car later that day, fan ran for about 15 -20 sec cut out (presume blown fuse but to dark to check). anyone have any ideas where I should start looking for problem????
  8. heater fan
    Aug 2006
    Would taking the car and putting on a dealer's computer show the problem or would it basically say you've got a blown fuse?????
    Does it tell you why or where the problem is????
  9. Re: Climatronic Display
    7 Post(s)
    I'd turn my attention to the fan resistor pack.
    Have you looked on here yet for anyone who can read the car for faults ?
    Look in the vagcom sub forum
  10. Re: Climatronic Display
    Aug 2006
    Update so far
    Finally bit the bullit and took car to a local garage which specialised in electrical problems, Fault turned out not to be electrical but a broken air con compressor, (approx cost to fix - just short of £500), he did however remove the relay which came in when the heater fan started and was blowing the fuses so I am now able to clear my windscreen and have heat in the car but when summer comes I wont have aircon (until I repair it). total cost so far £20:51 for diagnostics (pretty good eh!.)
    PS : thanks to Big Col for all his help, which without I would still be looking in the fusebox.
  1. CLIMAtronic HELP!!
    By s0niX in forum Polo - Derby - Lupo - Fox
    Last Post: 13-05-2007, 01:35 PM
  2. Climatronic display flashes but is operational?!
    By TDi_B5 in forum Passat - Archive Topics
    Last Post: 12-02-2007, 04:40 PM
  3. Climatronic Display - 2002 Tdi 130
    By jdncl in forum Passat - Archive Topics
    Last Post: 08-12-2006, 02:11 PM
  4. Climatronic and ECU
    By johnlund in forum Passat - Archive Topics
    Last Post: 13-10-2006, 04:54 PM
  5. Climatronic Display
    By kev2963 in forum Passat - Archive Topics
    Last Post: 13-03-2006, 01:44 PM
