Thread: turbo spooling?
Results 1 to 10 of 11
  1. turbo spooling?
    Nov 2008
    Is it normal to hear your turbo spooling, whooshing and sometimes fluttering inbetween gear changes ? mine does this all the time.just wondered if i have a split pipe or something. no modifications, just bog standard.
  2. Re: turbo spooling ???
    46 Post(s)
    On both cars I hear both turbos whistling, spooling and dying off when off the throttle ever since day 1 of ownership.
    if you had a split pipe you would have no or little boost and limp mode from memory. only when it starts whining like a police siren is when you start to worry
  3. Re: turbo spooling ???
    Jan 2011
    Stafford, UK
    No turbo sounds from my 2.7 TDI.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  4. Re: turbo spooling ???
    46 Post(s)
    Quote Originally Posted by royclark View Post
    Saying that, I can only hear it on my A6 with the windows down.
    Can hear the A3s more due to it being a noisy PD.
  5. Re: turbo spooling ???
    Sep 2011
    Lurking over a keyboard ...
    On my A6 I can note it if I listen very very carefully when driving with windows up and music not on and with windows down I notice it more but compared with my VAG TDi vans I've got to say it really is quieter ...
    IMO the 2008 2.5 TDi common rail did more turbo spool noise than my 2012 2.0 TDi common rail, when I compare the 2005 A6 3.0 TDi common rail to them it is so much more refined ...
    More often I hear the dying off after releasing throttle than any operational noise of turbo ...
    Differing engines do have differing turbos ...
  6. Re: turbo spooling ???
    Feb 2013
    Measham Derbyshire
    Don't hear much really on mine. As gupsterg said, only hear it with windows down backing off the throttle and no System Of A Down playing on the stereo! Needless to say the combination of those things happening are rare lol.
    I have heard quite prominent whooshing etc on other older turbo diesels, so the sounds you hear are not out of the ordinary. But maybe worth having it checked out just to be sure
    Audi A6 3.0TDi Quattro Le Mans '08
  7. Re: turbo spooling ???
    Nov 2008
    hmmm, doesn't sound anything like that, just a whoosh on gear change, a bit like a dump valve.
  8. Re: turbo spooling?
    Mar 2009
    Essex
    A local taxi driver with a passat tdi and a whining turbo seemed to think that it's bearings were on the way out.
  9. Re: turbo spooling?
    Colchester,Essex
    Have you checked if the intake pipe on the turbo tight?
  10. Re: turbo spooling?
    Sep 2008
    mostly in the garage
    Quote Originally Posted by boidy View Post
    What engine do you have???
    There was a TPI issued about this concern on all PD engines.......not a problem apparently..
    Technical product information Transaction No.: 2006406/8
    Noises from boost air system on 4 cylinder TDI Release date: 10-Jun-2008
    Customer statement / workshop findings
    On vehicles with 4 cylinder pump injector engine a flowing noise is created in the boost air system when releasing the accelerator or at load change when disengaging the clutch.
    Technical background
    The noise is caused by structural tolerances (e.g. impeller fan). More than 2 bars of boost pressure cannot be noiselessly controlled as this leads to slight pressure fluctuations, which, depending on the tolerances, can lead to noises on parts in the boost air system. But because of different frequency superimposition the noise cannot be reproduced on all vehicles. The noise is normal and doesn’t affect the service life of the turbo charger.
    Production change
    Measure
    Do not replace any parts as this doesn’t improve the situation.
    Customer information
    When accelerating the maximum boost pressure is reached just above 2000 rpm. If the engine speed drops after releasing the accelerator, the drawn-in air accumulates and flows back. The resulting quiet flowing noise can only be heard briefly and is no technical complaint in the sense of warranty. It is a normal condition on all vehicles with 4 cylinder pump injector engine.
    1 1 0
  1. Replies: 1
    Last Post: 14-06-2012, 09:02 AM
  2. Blown turbo. Is it possible to replace a k03 turbo with k04 turbo
    By A4slineavant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2012, 07:45 AM
  3. 2.0tdi bkd turbo not spooling on startup
    By patmcnamara78 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2011, 11:03 PM
  4. New Turbo Spooling too early?
    By ads1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-04-2011, 02:57 PM
  5. MK3 TDI turbo dying... remap or hybrid turbo?
    By leoninanegg in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2007, 08:48 PM
