Thread: Excessive brake noise !
  1. Excessive brake noise !
    Dec 2007
    Belfast
    Hi All.
    The car is a MK4 1.6s 16v 2001 AZD 85,000mls.
    Had new discs and pads fitted around march with the discs and pads being bought from GSF, and for a while, everything seemed fine.
    After a while I started getting a metal scoring binding type of sound coming from the front of the car, especially noticable when driving in built up areas. I am currently experiencing a loud squeeling noise when braking when the car is warmed up.
    I am thinking a bit of grease may help things for a while.
    Are the problems I am experiencing due to having cheap discs and pads ?
    I was thinking about getting new pads from VW in the hope that it will solve the problem.
    Any ideas, info or help appreciated.
    Thanks.
    Marko.
  2. Re: Excessive brake noise !
    Sep 2011
    Lurking over a keyboard ...
    I would have thought GSF would supply OE quality discs/pads, what brand were they?
    I fitted Pagid discs/pads on an Audi A6 Avant 3.0 TDi quattro no issues, they replaced genuine discs/pads ...
  3. Re: Excessive brake noise !
    Aug 2011
    Meath
    Could be a pebble or the dust cover. Just turn up the wireless!
  4. Re: Excessive brake noise !
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Did the pads have the anti-squeal plastic coating on the piston/ caliper contact areas ? If not it's essential to use a smear of copper anti-sieze paste in these areas. I've used GSF Brembo high carbon discs for many years without any problems.
    Skoda Octavia II SE 1.9PD TDI
  5. Re: Excessive brake noise !
    46 Post(s)
    Didn't know there was a GSF in Belfast, I know there's ECP over on Falcon Road but everydays a school day.
    As advised, check for any grit or stones and you used copper grease when fitting
    0 2 0
  6. Re: Excessive brake noise !
    Sep 2013
    Galway , Ireland
    Did you get back to the supplier - sometimes a 'faulty' batch of discs/pads can cause problems and they may have had complaints from others .
    As said above GSF parts are generally good .
    Were shims etc put back ? a dab of anti- squeal grease worth a try.
  1. Excessive Road Noise
    By PJ300 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-01-2024, 11:21 PM
  2. Polo 1.4 9n - Excessive Wind noise
    By Running Monkey in forum Polo - Derby - Lupo - Fox
    Last Post: 26-04-2010, 07:37 PM
  3. Please Help Excessive noise
    By grahamchet in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-11-2009, 05:31 PM
  4. excessive wind noise
    By qa15ar in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-01-2009, 12:57 AM
  5. Excessive Brake Travel
    By jay77 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-04-2007, 10:20 PM
