Thread: Coolant leak, 1.9 tdi engine (rear hose/flange assembly)
  1. Coolant leak, 1.9 tdi engine (rear hose/flange assembly)
    Sep 2013
    Darlington
    Hi, I'm new to the forum and just left my introductions in the hello section.
    So the problem as the title suggests;
    I have a 2000 w-reg A4 Avant B5 with a 1.9 TDi. About 4 months ago I had a small coolant leak that I found was coming from the hose that comes from the back of the engine block and runs to the bulkhead and presumably the heater matrix. Specifically the leak seems to be coming from the plastic connection bit just before the right angle section turns it into a flange connecting to the engine block. I stuck a bottle of k-seal in (I know risk of blocking up all sorts of bits and bobs) which gave me a temporary fix, for about 4 months. However the leak has now returned and I'm topping up the coolant every couple of days.
    I've done quite a bit of searching, both on this forum and across others, and it would seem the most likely culprit will be a seal within the flanged right angled hose connector bit. Now I've had the turbo air feed pipe off the top and can just about see the offending connector that I need to get off.
    I guess my question is... has anyone done this before (I assume yes) and if so any tips. Any hidden bolts, star drive heads etc. A photo of the removed part would be handy too if there are any about, I can see where all the pipes etc are then before I begin.
    Thanks in advance,
    Adam
  2. Re: Coolant leak, 1.9 tdi engine (rear hose/flange assembly)
    Sep 2013
    Darlington
    Still haven't had chance to sort this yet, busy weekend, hopefully this weekend coming I'll get chance... getting sick of driving to work with a 5 litre bottle of water with me now
  1. A4 2.7 TDI Coolant Leak - Top hose replacement?
    By PJK in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-10-2012, 09:58 PM
  2. Replies: 8
    Last Post: 19-04-2012, 06:43 PM
  3. Question Coolant flange leak on a 1.6 A3
    By welshrabbit in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 14-11-2009, 12:11 PM
  4. Question A4 tdi Leaking coolant. Should I just change o-ring or the whole flange?
    By vTek in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2008, 10:23 AM
  5. 1.9TDi Coolant Water Leak Rear of Engine - Advice Please
    By delta925 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-10-2007, 11:23 PM
