Thread: upholstery
  1. upholstery
    Sep 2013
    oxfordshire
    hi, can someone give me an idea on how to get what i think is grease,off the drivers seat, tried a few products but to no avail.
    thanks for any help.
    grubby
  2. Re: upholstery
    Aug 2011
    Meath
    Is it car grease? Autoglym products are pretty good, or you could try steam cleaning it
  3. Re: upholstery
    mjhamilton Guest
    as above - interior foam cleaner with a soft scrubbing brush or a stream cleaner will remove most of the deadly sins from most materials
  4. Re: upholstery
    Aug 2011
    Meath
    Easy start will dissolve grease too not sure what it does to car interiors
  5. Re: upholstery
    Pembrokeshire
    22 Post(s)
    brake cleaner. spray it on, wipe it off, simples, probably won't harm the fabric. say probably as it most probably won't and i have never harmed anything with it. in fact it removes grease from pretty well anything, especially brakes.
    2 1 0
  6. Re: upholstery
    Dec 2007
    Belfast
    No matter what you use, if it is water based, the grease will repell the product. Try using some neat washing up liquid like fairy or persil, these cut through the grease. Start from the outside edges and work inwards and don't be rubbing too much on just one spot as you could damage the upholstry. Once the soap has been applied and left for 5 mins, wipe it with a clean damp microfibre. Repeat if neccessary.
    Good luck.
    Marko
  1. Grubby upholstery
    By mickyboy22 in forum General Detailing/Cleaning Questions
    Last Post: 05-08-2011, 05:42 PM
  2. Question upholstery cleaner
    By willwad82 in forum General Detailing/Cleaning Questions
    Last Post: 16-09-2010, 10:21 PM
  3. Re Upholstery M4
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 24-09-2008, 06:17 PM
  4. A4 Upholstery
    By undertaker in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-09-2008, 08:19 PM
  5. upholstery
    By nerrad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-07-2007, 11:45 PM
