Thread: Poor Servicing - Engine oil overfilled.
  1. Poor Servicing - Engine oil overfilled.
    Nov 2010
    Middle of nowhere
    I'm beginning to discover that the Inspection service the garage (non-Audi) did before I bought the car was perhaps little more than a oil change or top-up and a cursory kick of the tyres.
    Even though the 'Inspection Service' was ticked in the book, several things were missed or ignored according to the service interval requirements:
    - Tyre pressures not checked, all tyres way below recommended minimums.
    - Pollen filters not changed
    - Fuel Filter not changed
    - Brake fluid not changed
    - Oil level way too high (difficult to tell if it was replaced).
    Is there an easier way of draining off some oil other than removing the sump plug? If the level is too high, will it damage the engine? (Its higher than the Max level on the dipstick)
  2. Re: Poor Servicing - Engine oil overfilled.
    Nov 2009
    46 Post(s)
    From reading online during the years, having an overfilled engine with oil can lead to the turbo sucking the oil and chewing the engine and causing a runaway engine and chewing it to bits in turn. This is rare but it can happen.
  3. Re: Poor Servicing - Engine oil overfilled.
    Aug 2011
    Meath
    You can suck the excess oil out with a vacuum fluid extractor. I suggest you get the AA/RAC to check over the car and give you a report with a view to getting the seller to have it serviced properly. The report won't cost much probably little more than the cost of getting the oil removed. As Chris said you can do a lot of damage with too much oil probably best not to drive it
  4. Re: Poor Servicing - Engine oil overfilled.
    Sep 2011
    Lurking over a keyboard ...
    Feel for you mate, it's such a shame when people selling cars operate in this manner ...
    I've always had used cars and always after purchase do a service ...
    I'd be very tempted to do a oil change plus oil filter now. Quantum oil is Castrol EDGE, cheaply available on ebay. I once had to drain oil by loosening sump drain plug after a little overfill by a garage, luckily did not leak after tightening back up ...
    Fuel filter was very easy to do on my car, some info RE the 2.0 TDI in here Link:- Fuel Filter Change
    Pollen filter chamber I hoovered mine out before renewing (Link:- VW AUDI Forum - VWAF). It was clean this time but you should have seen it the first time I did it. My car had FASH but TBH was very poorly done even by dealers IMO.
    I got brake fluid change done part of another job for £40 ish but Audi @ £59 is not too bad either Link:- Fixed-price servicing < Servicing with Audi < Owners area
  5. Re: Poor Servicing - Engine oil overfilled.
    Dec 2010
    Chester Cheshire
    I once overfilled a Rover 400 company car I had. I went like s***t off and shovel. only problem was that with the key out engine was still going at full rpm. Could hear the bottom end starting to give up. Quite disturbing really !
  6. Re: Poor Servicing - Engine oil overfilled.
    Aug 2011
    Meath
    The problem I would have is that it would cost a dealer max £100.00 to do a service and change the brake fluid. If he stamped the book without doing the work that's misleading IMO. He overlooked the tyre pressure too not a big deal but if he couldn't be bothered to do that what else did he overlook?
  7. Re: Poor Servicing - Engine oil overfilled.
    Aug 2011
    Meath
    I agree Gup and like you I do all my own work. If he can't do it himself it will cost him at least £200.00 that's a years road tax or a dirty weekend!
    Quote Originally Posted by gupsterg View Post
  8. Re: Poor Servicing - Engine oil overfilled.
    Apr 2013
    Solihull, Great Britain
    I heard that overfilling the engine oil can cause the big ends to froth up the oil, causing fine air bubbles be drawn along all the oil galleries with the oil, causing increased friction and premature engine faliure. Ditto the turbo. Bristol Street Motors, main B'ham Ford dealer were most apologetic when I took my last motor back and showed them how overfull the sump was. Didn't stop them doing the same every year after that, though.
    12-plate Audi A3 Black Edition 2.0 TFSi S-tronic Sportback in Ice Silver with DVD Sat Nav, Bose sound system, xenon headlights, Bluetooth, voice control, heated full leather seats, full electric driver's seat adjustment, privacy glass, heated auto dimming power-folding mirrors, titanium grey Rotor-style alloys, auto lights & wipers, and tyre pressure monitoring.
  9. Re: Poor Servicing - Engine oil overfilled.
    Sep 2010
    Dublin, Ireland
    Bring it back to them mate ...
    Rob
  1. Overfilled with oil!!
    By joedredd in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-03-2012, 02:55 PM
  2. Replies: 3
    Last Post: 23-02-2010, 06:38 PM
  3. overfilled engine oil
    By stevieg73 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-10-2009, 10:49 PM
  4. Replies: 3
    Last Post: 17-02-2009, 01:54 AM
  5. bora overfilled oil
    By bleedinbreaks in forum Bora - 1998 - 2005
    Last Post: 09-04-2008, 08:27 PM
