Thread: Parrot MKi9200 with MMI 2G + Bose
  1. Parrot MKi9200 with MMI 2G + Bose
    Aug 2008
    Hi, i've put a deposit on a 2006 Audi A6 2.7Tdi Quattro after killing my 57' A6 2.0 S-line in flood water :S. I bought a Saab 93 convertible as an interim car and fitted a Parrot MKi9200 to it, and apart from the saab stereo being really pants, it worked well for music over bluetooth. The new A6 has already got bluetooth for phone, but i don't think it's suitable for music over bluetooth and it has no aux / AMI, but it does have Bose speakers.
    I want to remove the parrot from the saab, buy the appropriate leads and have it working through my new audi, so, firstly, what lead do i need, (SOT-906?) and is it a simple job or do i need to connect my car to a VAGCOM machine to enable Aux or anything? (i did on my saab). Has anyone got the same setup?
    I had DAB installed on my old A6 too but it isn't on my new one, is it just a matter of buying the DAB module and aeriel like Genuine audi DAB radio tuner module A6 S6 RS6 A8 S8 Q7 A5 A4 S5 S RS4 | eBay, and fitting it?
    Regards, Wez
  2. Re: Parrot MKi9200 with MMI 2G + Bose
    46 Post(s)
    You won't be disappointed with the AMI, adding the parrot to mmi is a phaff I believe and requires an expensive adapter lead.
    Something like this is significantly cheaper than AMI but still uses the same interface and looks 100% OEM - will be buying one next month for my a6. VNS AMI Audi MMI 2G iPod iPhone Interface A5 A6 A8 Q7 | eBay
    That dab link is everything you need.
  3. Re: Parrot MKi9200 with MMI 2G + Bose
    Aug 2008
    I don't have AMI, i did in my old A6, not in this one, and i don't have an iphone / ipod, only a Samsung Galaxy S4. I Believe it's the SOT-906 lead i need which is £45?
  4. Re: Parrot MKi9200 with MMI 2G + Bose
    46 Post(s)
    Yep that looks like the one - remember you'll need he extension lead as you'll be working from the boot area to wire it in.
  5. Re: Parrot MKi9200 with MMI 2G + Bose
    Aug 2008
    Thanks,
    How will it work then, will my bluetooth connect to both the parrot and the Audi bluetooth? Also, what extension lead will i need? Thx
  6. Re: Parrot MKi9200 with MMI 2G + Bose
    46 Post(s)
    According to this - Autoleads SOT-906/BOSE Audi A6 Parrot SOT Lead
    Under the compatibility tab- you'll need the extension lead as you'll be plugging it directly into the amplifier apparently.
  1. Please Help Parrot MKi9200 kit into an A3 with Symphony+Bose
    By jenik1914 in forum In Car Entertainment
    Last Post: 26-05-2011, 09:34 AM
  2. Question Parrot MKi9200 in a Passat B5.5
    By Jamiem in forum In Car Entertainment
    Last Post: 15-12-2010, 05:28 PM
  3. Parrot MKI9200
    By a4_cab in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-01-2010, 10:20 PM
  4. Parrot MKi9200/RCD 300 Problems/
    By Brendanm76 in forum In Car Entertainment
    Last Post: 23-10-2009, 12:01 PM
  5. Parrot MKi9200 in a New Golf V
    By ipilot in forum In Car Entertainment
    Last Post: 18-12-2008, 10:01 PM
