Thread: brake fluid still coming from filler cap?
  1. brake fluid still coming from filler cap?
    Oct 2012
    Wakefield
    Changed the brakes and discs other day and some came out when I pushed the pads back.
    could smell fluid today when driving so had a look, more has come out of the filler cap,
    should I be worried or is it just levelling itself out?
    the car has no fault lights on and is braking well.
  2. Re: brake fluid still coming from filler cap?
    Pembrokeshire
    22 Post(s)
    you need to remove some fluid so its sat at the 'max' level mark. using the brakes heats the fluid, fluid expands, has to go somewhere, out the cap if its too high already.
  3. Re: brake fluid still coming from filler cap?
    Aug 2011
    Meath
    Has Mrs Batt got a poultry baster? It's perfect for this job
  4. Re: brake fluid still coming from filler cap?
    Oct 2012
    Wakefield
    Quote Originally Posted by Doctle Odd View Post
    Thanks for the advice, I removed approx 30-40ml with a syringe,
    although for every bit I removed, the level raised back up after 1-2 seconds,
    bizarre I know......?
    Ive been for a long drive and there has only been a tiny trickle this time,
    rather than being covered in it
  5. Re: brake fluid still coming from filler cap?
    mjhamilton Guest
    Make sure you wash off any drips and overspill as brake fluid is corrosive and will eat paint and rubber
  1. Question Brake fluid seeped out of filler cap when changing brakes..?
    By battmiceter in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 31-08-2013, 08:11 AM
  2. Filler Cap Gunge
    By venetian-red in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-01-2010, 09:19 PM
  3. Question Passat brake fluid cap and dip stick required.
    By matt111074 in forum Early Passat Forum - Pre 97
    Last Post: 25-04-2009, 01:39 PM
  4. Oil filler cap
    By theshug in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-02-2009, 10:11 AM
  5. Brake fluid cap query?
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-06-2008, 08:16 PM
