Thread: Switched feed- which fuse box
Results 1 to 10 of 20
  1. Switched feed- which fuse box
    Jul 2013
    Oldham
    Hi all
    I have a blackvue in car camera and want to wire it in as a permanent fixture to keep all the wires hid as well as possible
    I want to hard wire it straight in the fuse box but am unsure which fuse box to go to.
    Should i goto the drivers or passengers fuse box and which fuse carrier black/brown/red for a switched feed
  2. Re: Switched feed- which fuse box
    46 Post(s)
    You should have a fuse box in the end panel of your dash.
    I'm watching this thread with interest as I too have just bought two Blackvue's for both cars and wanting a switched feed
    This post here is what I'm looking for - Non vag black box dash cams? - Page 2
  3. Re: Switched feed- which fuse box
    Jul 2013
    Oldham
    was reading the handbook and it says there should be a drivers and passenger fuse box, just need to know which fuse box/ colour I need to aim for
  4. Re: Switched feed- which fuse box
    Dec 2012
    Gwent
    +1
    Very tempted to get one of these Blackvue's
  5. Re: Switched feed- which fuse box
    Apr 2007
    Surrey
    I'd also like to know where I can find a switched live in the drivers side fuse box so I can hardwire a feed for my Tomtom...
    Have you seen these?
    http://www.co-star.co.uk/range/363/fuseholders-&-fuses/add-a-circuit-fuse-holders.html
    Hopefully someone will share their pearls of wisdom with us soon
    2009 A4 2.0 TDI (170) Avant S Line Exec. ​Quartz Grey, S Line suspension (Optional), Bluetooth phone prep low, AMI, DAB, Symphony III, Leather/Alcantara, rear sun blinds, heated/dimming/folding mirrors and cruise control. Mods so far: BBS LM (reps), spacers (10mm f, 15mm r), needle sweep, dipping mirror on reverse and badge delete. To come: LED rear lights, lows and rear window tint.
  6. Re: Switched feed- which fuse box
    Jul 2013
    Oldham
    ok, looking the handbook I think, drivers side black and brown fuse carriers are switched from what the have on them and red is permanent because it does things like interior light, sunroof etc Passenger side I reckon black is switched because it does diagnostic connector and brown is permanent because it does light switch etc.
  7. Re: Switched feed- which fuse box
    Jul 2013
    Oldham
    also, a bit off topic, I see there is a fuse for clutch sensor. so, using cruise control when I dip the clutch cruise stays active yet in my old car dipping the clutch would deactivate it. is this just an audi thing or could my clutch sensor be an issue, cheers
  8. Re: Switched feed- which fuse box
    46 Post(s)
    That's normal for cruise.
    Check each fuse with a multimeter with the key off and on, I'll be doing this tomorrow on the a6.
  9. Re: Switched feed- which fuse box
    Jul 2013
    Oldham
    normal that it doesn't go off when clutch is dipped? I don't have a multi meter, really need to get one, can you let me know what you find please
  10. Re: Switched feed- which fuse box
    46 Post(s)
    Quote Originally Posted by Sparky_143 View Post
    Yep, normal that it doesn't go off when you dip the clutch to change down or up, tap the brake and it will go off. Same as my A3.
    I don't have one either but a spark next door will have one. Not sure how much use of it will be suitable as my A6's fuse panel is probably different than your A4.
  1. I've found a switched ignition feed......
    By jimmies78 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-04-2012, 08:41 PM
  2. Fuse box or live feed, anyone tried taking the analogue clock out ?
    By sj_4x4 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 19-09-2011, 05:01 PM
  3. Getting 12v feed from fuse box with multimeter.
    By snoop2048 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-04-2010, 01:16 PM
  4. Diagram or photo of what each fuse does in Fuse box on 2000 Polo , Please
    By t_basham@hotmai in forum Polo - Derby - Lupo - Fox
    Last Post: 04-08-2009, 05:12 PM
  5. Switched Ignition Feed
    By MattyA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-03-2009, 08:33 PM
