Thread: Brake fluid seeped out of filler cap when changing brakes..?
  1. Brake fluid seeped out of filler cap when changing brakes..?
    Oct 2012
    Wakefield
    When I pushed the brake calipers back,
    brake fluid leaked from the filler cap even thow it was tightened up!
    does this mean I have bust it the reservoir?
  2. Re: Brake fluid seeped out of filler cap when changing brakes..?
    Pembrokeshire
    22 Post(s)
    as the level drops as the brakes wear, air must be able to get in or a vacuum would form which would be no good. air must also be able to escape as the fluid heats up and expands. basically there will be a vent hole in the cap which fluid will go through if forced, so no, you havn't broken anything. however, next time, loosen the bleed nipple on the caliper you are pushing back and use some tube to flow the fluid into a container, rather than pushing it back through the abs pump and master cylinder, which can often end in tears.
  3. Re: Brake fluid seeped out of filler cap when changing brakes..?
    Aug 2011
    Meath
    You could have been unlucky and ruined the ABS pump an old piece of vacuum pipe on the nipple is all you need. Makes them easier to push back too
  4. Re: Brake fluid seeped out of filler cap when changing brakes..?
    Oct 2012
    Wakefield
    Thanks,
    What is the correct procedure, do I loosen the bleed nipple then push the pad back?
  5. Re: Brake fluid seeped out of filler cap when changing brakes..?
    Aug 2011
    Meath
    Yes loosen 3/4 turn. An old piece of vacuum pipe or similar attached to the bleed nipple and the other end into an old bottle. Never re-use old brake fluid and replace it every 2 years
  1. Petrol Filler Cap
    By pmnpmn in forum Golf MK6 - 2009 - 2013
    Last Post: 05-09-2009, 12:12 PM
  2. Question Passat brake fluid cap and dip stick required.
    By matt111074 in forum Early Passat Forum - Pre 97
    Last Post: 25-04-2009, 01:39 PM
  3. Brake warning symbol but no problem with brakes or fluid!
    By Dudey Head in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 26-10-2008, 06:35 PM
  4. Question Changing Brake Fluid
    By Paulst in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2008, 12:55 PM
  5. Brake fluid cap query?
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-06-2008, 08:16 PM
