Thread: Climate control
  1. Climate control
    Aug 2008
    Derbyshire
    Hi Guys, been over on the A4 forum for a bit then over in the Skoda Superb area now looking to take the plunge with the A7.
    I have noticed a couple of things - many of the cars on autotrader seem to have a screens that have large bezzels (a lot of gap between the edge of the flip out screen and the beginning of the actual screen) and that reviews on the internet I have seen have had digital temp readings on the dash like the A6 but those on that are on autotrader do not..... It almost seems as if it is a step backwards from the A6??
    Are these optional extras for a larger screen and digital temp readings?
    Damien
    B8 Avant 2.0 SE TDi 143 Phantom black, de badged with NAV and Cruise
  2. Re: Climate control
    Feb 2013
    Gloucester
    57 Post(s)
    I've done quite a lot of research and recently ordered mine. Yes there are two different screen sizes. The one I took my test drive in seemed small and as you say too much plastic around it however there is a larger one available. As for the digital thermometer, this is shown only on the DIS between the speedo and rev counter I believe.
    Sent from my iPad using Tapatalk HD
  3. Re: Climate control
    Oct 2012
    Spalding (Sometimes)
    I think you refer to the temp display for the aircon?
    On standard climate you just get a pair of knobs to turn to set the temp
    If you spec the 4 zone climate control option then you get the 2 digital displays in the centre console (and 2 more in the back) that show the temp set.
    As for screen size, even the larger screen has quite a bit of plastic around the edge
  4. Re: Climate control
    Feb 2013
    Gloucester
    57 Post(s)
    Ah good point, I thought he meant he outside air temp display.
  1. Question climate control blower failure/resistor pack/ control panel ?
    By ianmcneill in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-08-2011, 10:00 PM
  2. Replies: 2
    Last Post: 08-08-2008, 10:53 PM
  3. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
  4. climate control
    By madmonk in forum Golf MK4 - 1999 - 2004
    Last Post: 15-01-2008, 10:40 AM
  5. A/C to climate control
    By davegilsenan in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-07-2007, 08:10 PM
