Thread: '96 cabrio window electrics
Results 1 to 10 of 10
  1. '96 cabrio window electrics
    Aug 2007
    Philadelphia
    The driver's doesn't work at all unless you take off the door panel and use jumper wires. Have changed out the switches without solving the problem.
    The other windows obey the top down sequence, but not the switches.
    I have a digram from ADHOL, but is not quite right (only shows 5 switches and my car has six).
    Can anyone share the diagram with me? I think if I have the right diagram that I can get the wiring problem worked out without ripping the interior apart too much.
    Thanks,
    Charlie Affel, Philadelphia, PA
  2. Re: '96 cabrio window electrics
    134 Post(s)
    2005 Post(s)
    Send me your chassis number (I can spot on ID the car to the diagram from the number) by private message and also your email address and I will email you the diagrams. I am away for a few days so when I get back on Friday I can send it.
  3. Re: '96 cabrio window electrics
    Aug 2007
    Philadelphia
    Thanks for the offer,
    I'm centering my attention on the power window control module right now.
    Output appears to be 2v, instead of 12.
    the right diagram would help.
    What does the control module look like.?
    It seems to be buried under some other components
    Charlie
  4. Re: '96 cabrio window electrics
    134 Post(s)
    2005 Post(s)
    Delete your email and chassis number now.
  5. Red face Re: '96 cabrio window electrics
    Aug 2007
    Philadelphia
  6. Re: '96 cabrio window electrics
    May 2008
    Does anyone have wiring diagram for 1993 audi 2300cc cabriolet roof please please
  7. Re: '96 cabrio window electrics
    Nov 2008
    Hi folks, I have a 1996 Audi Cabriolet and the drivers electric window wont work. I can open all the other windows but only via the centre consol switch. The passenger door switch does not operate the passenger window. I assume this is all related. I have replace the motor on the drivers door but still no luck. No wiring diagram so I'm now stuck. Any ideas? Cheers Pos
  8. Smile Re: '96 cabrio window electrics
    Hello mate i had this problem and its the big double relay underneath the steering wheel where all the other relays live, mine had the number 262 on it.
  9. Re: '96 cabrio window electrics
    Nov 2008
    cheers cookie, I'll give it a try.
  10. Re: '96 cabrio window electrics
    May 2008
    Hi i had same problem with mine was wiring going through from door to the car inside the big black tubular grommet,wires had broken with door opening and closing
  1. Wet Electrics - Alarm tip
    By guyg in forum Archive posts
    Last Post: 17-03-2007, 11:20 AM
  2. probs with electrics
    By r1ytm in forum Passat - Archive Topics
    Last Post: 18-02-2007, 01:21 PM
  3. A4 Door electrics
    By acegadget in forum Archive posts
    Last Post: 30-01-2007, 11:18 AM
  4. NO ELECTRICS
    By salty in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 29-01-2007, 08:40 PM
  5. 80 tdi electrics
    By Buffer in forum 80 - 90
    Last Post: 02-08-2006, 07:01 PM
